What all is needed for a TH400 to a 200-R4 tranny swap
I know this has been beaten to death, but I can't find all the info in one thread. What exactly is needed to swap out my TH400 for a 200-R4. Car is a 75 with GM Performance Parts 350/330. Not racing the thing just looking for some extra gear for cruising. Car also has a 390 rear. Thanks in advance and if I havn't looked in the right place or missed the right post. Sorry.
There is a recent thread on this.
New Crossmember
Torq converter
Shifter kit (the one with the detents and silk screen for the shifter)
Kickdown cable
Don't know if the driveshaft needs mod for a 400 to 2004r swap, someone will
I would also go with a better cooler than stock
thats really it for the swap. What do you have in mind for the tranny itself?
New Crossmember
Torq converter
Kickdown cable
Thanks guys. For the tranny, I have one from a friend. there is a really good tranny guy in the area, will rebuild and modify/beef up as needed. Isn't there an electrical connection involved somewhere for the lockup
Check out bowtieoverdrives.com. There is lots of info and they have everything you need to make it a simple change over. I bought mine through them and they were very helpful. It is a great mod if done correctly.
The cross member is fine but you do have to get a different yoke and front universal to hook up to the drive shaft. You need a TV cable and a way to hook it up to your carb. I had to replace my brake switch with one that has two sets of contacts so the converter will unlock if you step on the brakes. The way BTO setup the trans lockup converter is that it locks when in forth gear (OD). I wasn't happy with having to downshift every time I slowed down to unlock the converter so I installed a B&M controller that uses the speed to control the lock-up around 40mph.
You will want to get a detent plate so that your shifter will match the trans positions and you may have to rework your neutral safety switch.
The other thing that you will need is a bracket for the steering column lock. I had to make my own or disconnect it all together. I have made several for other forum members and it was not that difficult.
You will need to hook up a pressure gage to the trans when you first adjust the TV cable. Once that is correct you will not need it again.
