Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-20-2009, 08:42 PM   #1
rgpta
CF Member
Support Corvetteforum!
Default Replacing 1976 Floor pans
Hello All,
New to the forum, just purchased my first Vette, a 1976 Stingray. Today I started restoration. I need to replace the floor pans. I was wondering if I need to remove the body to do this.
Car runs great, but needs body and interior restoration, so was hoping I didnt have to remove the body and build a dolly for it.
Any help or references deeply apprecisted
TIA
rgpta is offline   Reply With Quote
Old 08-20-2009, 09:08 PM   #2
markids77
CF Senior Member
Welcome to the forum and to Corvette ownership! Floor rust which requires major surgery is often accompanied (possibly caused by) Leaks in the windshield frame and/or t-tops. Do a search here on birdcage rust and you'll find a wealth of reading. If possible post some pictures of the floors with seats/carpet out, there are excellent craftspeople here who could recommend the easiest/best way to approach your specific repair. If you can get under the car, inspect your frame and body mounts closely for rust mites as well. Your avatar does not include your location... are you from the "rust belt"?
markids77 is offline   Reply With Quote
Old 08-20-2009, 09:19 PM   #3
rgpta
CF Member
Thanks for the quick reply. I live in Connecticut. Purchased the car out of Chicago, got a good deal.
Old 08-20-2009, 09:22 PM   #4
rgpta
CF Member
where is the search function on the forum
Old 08-20-2009, 10:20 PM   #5
c3_guy
CF Senior Member
c3_guy's Avatar
Quote:
Scroll to the top of this page, it is in the red header bar.
c3_guy is offline   Reply With Quote
Old 08-20-2009, 10:34 PM   #6
markids77
CF Senior Member
Road salt both locales... not a good sign if the car was driven beyond the "season". I do recommend a close look underneath, and at the 'cage. Like most 30 year old autos, these cars can show their age underneath the "makeup".
Old 08-20-2009, 10:36 PM   #7
63Nova
CF Senior Member
63Nova's Avatar
Shouldn't need to remove the body.
When it comes time to weld let me offer this advice, having just done floorpans for the first time in my life. Set the welder to almost the lowest setting possible. And use gas shielded wire, no fluxcore.
63Nova is offline   Reply With Quote
Old 08-20-2009, 10:36 PM   #8
rgpta
CF Member
I am new to this, what exactly is the cage and/or birdcage?
Old 08-20-2009, 10:43 PM   #9
markids77
CF Senior Member
The birdcage is the steel (from late 1975 up) floor, door sill and windshield frame which comprises the "core" of your car's body. All the fiberglass bits are bonded to this core, hence the importance of the core's integrity to ensure the strength and safety of your body structure. To search this subject, scroll to the top of this page. Left click in the triangle just to the right of the word "search", select to search just this catagory and input the single word "birdcage". Read it all... we'll see you after the new year!
Old 08-20-2009, 10:44 PM   #10
1976 corvette
CF Senior Member
1976 corvette's Avatar
I don't know how bad yours is but my 76 was rusted through. The replacement cost around $250 apeice and on a high school buget I didn't want to aford it so this is what I did.....
http://corvetterestoration.webs.com/...tterepairs.htm
P.S - I am going to trash my website with in a month or two to make a better one so nothing is going to be up dated.
1976 corvette is offline   Reply With Quote
Old 08-21-2009, 08:08 AM   #11
rgpta
CF Member
Thank you all for the information. WEB site is great
Old 08-21-2009, 01:13 PM   #12
markdtn
CF Senior Member
markdtn's Avatar
There are posts on this very subject, but may be older than you can search.
You can probably buy a later one for $100 or less. The 78-82 style floor is slightly different but seemed to hold up better for some reason than the 76 and 77. It can be used in a 76 or 77.
markdtn is offline   Reply With Quote
Old 08-21-2009, 03:52 PM   #13
20mercury
CF Senior Member
20mercury's Avatar
Default 76 floor pan repair
Agree, need to find the source of the water and fix. Could be the windshield frame. Pull the trim pieces on the inside and check for rust.
Anyway, I had a few holes in my 76 metal floorpan and quite a bit of surface rust. The area around the formed in nut for the seatbelts was still good though. Rather than buy a couple of new floorpans to install for $250/piece. I decided to wire brush the metal, paint with a rust converter, then paint with derusto, then install fiberglass fabric/fiberglass gel over the whole floor pan on the inside. Tape on the outside kept the fiberglass repair from dripping out. Afterwards go back and spray undercoating on the bottom of the pan. I think this repair might hold up a good while. Key I think is to get the rust treated and sealed. And I think you need to have enough metal floor pan left to provide some structual integrity to work with. Good luck!
20mercury is offline   Reply With Quote
Old 08-21-2009, 10:57 PM   #14
78Vette-SA
CF Senior Member
78Vette-SA's Avatar
Been there, done that. Easier with body off but can be done with body on.
http://www.vettetech.com/projects/c3...y/c3gsbody.htm
__________________
Email: Joe Santacroce
98 Black A4 Coupe Heads/Cam/N2O - 81 FrankenSport LS6SC/6spd/SRIII
78Vette-SA is offline   Reply With Quote
Old 08-25-2009, 02:39 PM   #15
rgpta
CF Member
what size rivets did you use to fasten the floor pans?
Will rivets alone hold the floor pans? I know they must be steel, how about galvanized
Old 08-25-2009, 02:54 PM   #16
...Roger...
CF Senior Member
...Roger...'s Avatar
got a good deal.
Once you dig in and find the extent of the damage you might not think it was a good deal. In some cases money wise its not a good deal even if they paid you to take the car. However the experience and fun of doing the resto you can't really put a price on. Good Luck
...Roger... is offline   Reply With Quote
Old 08-27-2009, 06:22 AM   #17
78Vette-SA
CF Senior Member
78Vette-SA's Avatar
I used 3/16" Stainless Steel rivets. I have a pneumatic reivet gun (They are about $50 from Harbor Freight if you have an air compressor) because stainless rivets with a regular hand rivet gun is a PITA.
I suppose it can be riveted on the inside. But keep in mind it's hanging there with all that weight (yours, passenger, seats, etc.). I would weld the inside and outside and only rivet the front where it meets the fiberglass. Can it be riveted only, yes. If you put a series of stainless rivets in it perhaps it will be strong enough.
Getting the new one in is easier then getting the old one out. Using a ROTO-BROOCH hole saw, a Sawzall, and a Big-azz hammer and chisel help alot!.
__________________
Old 08-27-2009, 07:33 AM   #18
rgpta
CF Member
thx for the advice, going to grab a spot welder for the job
Reload this Page Replacing 1976 Floor pans
Tags
1976, 76, body, c3, core, corvette, floor, floorr, pan, panels, pans, repairing, replace, replacement, restoration, stingray, support
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Trivia of the Evening-The 1976 was Known for... paul 74 C3 Tech/Performance 19 11-06-2002 07:08 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
