Links to old Tech Tips & hopefully some new contributions, too
Received 1,306 Likes
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
The Tech Tips section once available has not been accessible for updates for quite some time because the software used to create the material is no longer supported and is not compatible with the vBulletin software that runs the Forum.
It’s on a long list of “to-do” items to try and resurrect the section, but has not made it to the top of the priority list as yet. Meanwhile, Forum member C4Cruiser located the following links that allow viewing of the old tech tips and recommended that we share the links with others who might be interested in accessing them.
C1-C2 Related Tech Tips:
http://web.archive.org/web/200312201....php?TopicID=4
C3 Related Tech Tips:
http://web.archive.org/web/200310031....php?TopicID=3
C4 Related Tech Tips:
http://web.archive.org/web/200402021....php?TopicID=2
C5 Related Tech Tips:
http://web.archive.org/web/200306041....php?TopicID=1
Cross-generational Tech Tips:
http://web.archive.org/web/200402030....php?TopicID=5
Mike Schriber Reviews:
http://web.archive.org/web/200312201....php?TopicID=6
If you want to post newer tech tips, please post a link to them in this thread. If you know of other tech tips already posted, post a link here to them as well. That should make the task of getting the Tech Tips on track much easier when we get the necessary window of opportunity to make it happen.
Thanks.
Thanks.
Data Retrieval Failure.
We're sorry. We were unable to retrieve the requested data. We may be experiencing technical difficulties and suggest that you try again later.
See the FAQs for more info and help, or contact us.
I tried the C3 link this morning and it did not work. I used one of the other links and changed the last number in the URL to "3" and the page of links came up. Here is the address that I used to get to that page (it is a little different that what is in the link above).
http://web.archive.org/web/200406031....php?TopicID=3
info on parts for my new 72 454 vette
Does anyone have any recomendations on some parts that I need for my car.
I dont plan on racing the car, keeping it stock, but woulnt mind better performance.
1) water pumps,
there are so many brands, rebuilts, oem does anyone have a rec on a water pump
i have looked at emp stweart ,elgin ...
2) I have to pull out my radiator, it leaks, do I have it poressured tested and fixed if its under $200.00 and if its more should i purchase another copper brass or go aluminium
3) what corvette sites are the best for getting other items, windshield wiper motor,
master cyclinder
thanks in advance
1) water pumps,
master cyclinder
thanks in advance
Re: recommendations
Hi marryanne sent you a private message/PM, with regard to your request for information.Perhaps the Mods can help you out by moving this requst to C3 General our some place where it will get more attention than in "Links to old Tech Tips & hopefully some new contributions, too"
PS Welcome to the Corvette Forum.
ikwhite
ikwhite
1) water pumps,
master cyclinder
thanks in advance
1) water pumps,
master cyclinder
thanks in advance
