79 L82 cam choices
Old 08-11-2009, 09:25 PM
hotrodrik
hotrodrik's Avatar
Default 79 L82 cam choices
I'm rebuilding the engine in my 79. compression is 9.6:1 ,stock heads mild ported with 2.02/1.60 valves, auto with 3:55 gear , stock manifolds with 2.5 duels The two cams I'm looking at are Both Comp Cams XE256h and XE262h , my question is how is the drivabilityof these,and how are they for vacum ?any suggestions?
Old 08-11-2009, 09:51 PM
63Nova
63Nova's Avatar
If they are flat tappet watch out. The XE series of comp cams has been having many failures due to the extremely aggressive ramp rate of the lobes, even with people that use oils with enough ZDDP.
As far as the actual specs of the cam, you will be fine as far as idle, driveability, and vaccum go.
But if you want performance I would highly suggest some headers, you are leaving a good 15-20HP on the door with those stock manifolds.
Old 08-11-2009, 09:58 PM
Oldguard 7
Oldguard 7's Avatar
Either would be fine. I lean toward the 262. There are many forum members who have the 268 or 274 cam in their vehicles. They are not too radical of a cam therefore it will not pull too much vacuum with good driveability.
Old 08-12-2009, 12:25 PM
BKbroiler
BKbroiler's Avatar
I have the XE262H cam in my car. Very good vacuum with no drivability issues, although my engine is a 383. I use Valvoline racing oil (the one not recommended for street use). Four years with no problems.
Old 08-12-2009, 12:47 PM
gerry72
gerry72's Avatar
Ironically, the L82 cam is more performance oriented than the aftermarket cams you're looking at.
Old 08-12-2009, 01:29 PM
Scott Marzahl
Scott Marzahl's Avatar
I think I would go with the 270 magnum to avoid the XE lobe profile, its close to the L-82 cam. Another nice cam for this compression range is an Engle 1018H.
Part #: 1018-H
Grind #: EP-18/20HY
Int. 458"/ Ex. 468" Int. 216"/ Ex. 226" 112° LSA, ICL of 107
Old 08-12-2009, 02:08 PM
hwcoop
hwcoop's Avatar
With my 73 L82 I'm running a XE268 with 4spd, performer intake, headers and 2.5" pipes with Magnaflows. Nice Drivability, car idles at 800rpm & good performance Only vacuum I have to worry about is for my headlights (they pop right up!)
To 79 L82 cam choices
Quick Reply: 79 L82 cam choices
