72 corvette roadster:
Take a big heap of advice from the idiot that installed factory air on a 70 LT-1 Conv!
Really. . . And I mean really think this over! Then walk away!
Yes, you read correctly and I still own this car!
I did it, regret it and will remove it! There are some of you forum guys out there that are local and viewed this car and while it looks all AC’d up! I admit it, I’m the idiot. . . I’m a moron . . . why . . . because now I get to take all this off the car before I can finish it! This was by far my biggest mistake ever made on a Corvette!
I purchased this car in the late 1980’s and the car was not on the road for over 12 years before I purchased it. Some of you that viewed the CD or file on the windshield frame will recognize this yellow car as the 77k mile car used for this file. The car has not hit the road since 1977.
I have pictures . . . yes real Kodak pictures from 1992 when I got this bone headed idea. I can scan to show you what I did, but in a nut shell here I go.
You must remove the front end from the car to do a factory style conversion. You don’t have a choice if doing it factory! On a non air car there are two vents open on the driver side of the car, both were covered with a panel (number 4 and 5 in the picture colored blue) when the car was to have factory AC.
On the passenger side of the car you’ll find a special vent for AC cars that included a skeleton frame (number 1 in the picture and colored gray) that supported the abs plastic door and vacuum pod. This skeleton can not be installed with the front end on the car so you must remove it, fiberglass this in place and then re-install the front end.
Ok, next problem. You will need to remove the old heater box. Once you do this you will see the firewall pad and notice there is a perforation around the pad. This perforation was for installing the AC box on the car and is also the outline for the hole you’ll need to cut to install this new box. Yes, the box is larger and you will need to remove about 1” of fiberglass material. See picture below for details on how to cut this out.
18243
Next the reinforcement dash issue. You’ll need to round up some factory AC support rods for the dash.
Next you’ll need to figure the wiring out. The AC control harness was different from that of the non a/c cars.
While it may look simple you’ll have to modify the car in such a way that a normal person can not person can not reverse . . .
Other things that will need to be changed: Add condenser and brackets to the core support, change the heater control unit, change the shift plate, obtain all the AC ducts for the car and so on.
Ok. . . I’m done for now! Save your self some real trouble, either buy an ad on kit and install it, or look for a car with AC.
Anyone want to let me have it I understand! Anyone wants hands on lessons on how to reverse this. . . .Call my office and get directions. I’ll buy the beer! Thank god I saved everything I removed!
Willcox
