T-45rs
T-45rs
Anyone running/installing the T-45rs five speed yet?? I'm interested in what you think about this tranny. I'm considering installing one this winter.
Former Vendor
My motor was calculated by my engine builder (no dyno) to have 490HP 525Tq at the flywheel. Will the T45-RS handle this? I ONLY run street tires (255/60/15 BFG T/A) so they are the weak link in the whole car. They will spin before (hopefully) anything else breaks. I will admit I drive it pretty hard sometimes but that's what the BB is for isn't it?
Txredc3, I believe the T45RS-350 is capable of 350HP & TQ and the T45RS-425 is capable of 425HP & TQ
shmoky
Looked at the videos and I'm impressed. What rear gears is the yellow 69 running?? Are any floor alterations needed?? I'm definately leaning to this tranny.
Former Vendor
Gene, I found the video but it is a 69. Unless you have another of a 68 I couldn't find. Great video by the way. (I like the color too) I love the sound when accelerating
My fault yes it is a 69 sorry.
My motor was calculated by my engine builder (no dyno) to have 490HP 525Tq at the flywheel. Will the T45-RS handle this? I ONLY run street tires (255/60/15 BFG T/A) so they are the weak link in the whole car. They will spin before (hopefully) anything else breaks. I will admit I drive it pretty hard sometimes but that's what the BB is for isn't it? Well if street driven and only beat on a a little it may hold up.
I would recommend for your application the TKO spend a little more.
Correct
shmoky
Correct
shmoky
One small one but we send the template and sheetmetal.
This kit was designed for the lower hp C3's we see alot. Fitment is great and it will save up to $1000 over a comparable TKO kit.
Former Vendor
We give a $150 forum discount of the 4spd to 5spd kit. We also give $250 of auto to 5spd kits for forum members.
....My motor was calculated by my engine builder (no dyno) to have 490HP 525Tq at the flywheel. Will the T45-RS handle this? I ONLY run street tires (255/60/15 BFG T/A) so they are the weak link in the whole car. They will spin before (hopefully) anything else breaks. I will admit I drive it pretty hard sometimes but that's what the BB is for isn't it? .....shmoky
The T45RS would not be a good choice for this setup. The RS is rated at 425 at the input (4th gear), so you are 125ft/lbs over the limit and given your admission of " I drive it pretty hard sometimes" should exclude the T45 instantly.
I am not saying it wouldn't handle it, but it would not last. I would go either TKO or wait for the T56 magnum.
Richard
Tech Support
Richard
Tech Support
Richard
Tech Support
Richard, thanx for the honest opinion. I was hesitant on the T45 because I am hard on it sometimes. I will do a search on the T56.
shmoky
It is already out on the market. It is rated at 700ft/lbs, continuous at the input (4th gear).
What we don't currently offer is a C3 kit using the Magnum. We are working on it though.
Richard
Tech Support
Richard
Tech Support
I guess the question is "what kind of power does your "mildly" modified BB make"?
Richard
Tech Support
shmoky
St. Jude Donor '08
My stock BB engine has a little higher compression and a bigger cam, with polished heads, I dont know how much all that will equal in terms of HP/torque, maybe just 30-40 HP more.
St. Jude Donor '08
I haven't broke the M21 YET and I've been pretty hard on it. If the T45RS IS stronger then it might be enuf for me. HamadUP do you have anything besides just an "I believe" (or gut feeling?) to back this up? I'm not being a hardass here just trying to go to the T45RS as it is the cheaper route. If I can find something to justify it I will. Thanx.
shmoky
shmoky
