intake manifold GM
intake manifold GM
These are Gm numbers i can see on my intake 1401448? .Last number i cannot see .Aluminum small block.Black book no help .I suspect its a stock L82 intake .Any help?
Re: intake manifold GM (hiyosilver)
Try this one. That number is not Corvette.
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1804730714
[Modified by paul79, 8:43 PM 2/13/2002]
This is kind of close: #14014432. If your 8 is actually a 3 and the last number is a 2. That's the casting number for a 1981 aluminum 4 barrel intake. What application...you got me. I'll have to research more.
Re: intake manifold GM (79MakoL82)
If the number I posted above is correct, I believe that is a 1981 Camaro Z28 manifold for a 350 which is an aluminum high rise intake.
[Modified by 79MakoL82, 5:55 AM 2/14/2002]
