Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-13-2009, 11:52 PM   #1
ramair_bryan
CF Senior Member
Default head light switch removal
Hi guys..........It seems my elec problem has come down to the head light switch. so what is the easy way to remove it? 1981.......thanks again...bryan.
ramair_bryan is offline   Reply With Quote
Old 07-14-2009, 12:03 AM   #2
BigBlockTank
CF Senior Member
Drop the steering column from the dash, not pull it out. Pull all the screws that hold the drivers side dash, and tip it out from the top.
Well, that's how I have to do my 69. I don't know how much yours differs from mine. I've done it a few times now. Buy a great, not just good, but a great headlight switch.
BigBlockTank is offline   Reply With Quote
Old 07-14-2009, 08:14 AM   #3
RonR80
CF Senior Member
St. Jude Donor '09
RonR80's Avatar
I did the one on my 80 a while back and all I did is take off the small panel below the steering colum , if you have AC remove that pipe it attaches right there on the right of the colum and detaches from the right vent, reach up with your right hand , and there is a small spring loaded button you need to find, turn the switch on and push that little button and the light buttom will come out .Unscrew the nut and pull it out , then disconnect the wire plug , it's sounds hard but if you have the new switch just look at the spring button, it is keyed so it only goes in one way. Let us know how you make out, Ron
RonR80 is offline   Reply With Quote
Old 07-14-2009, 11:43 AM   #4
GunPowder
CF Senior Member
GunPowder's Avatar
can be done without to much effort - provided you have small hands
Click the image to open in full size.
GunPowder is offline   Reply With Quote
Old 07-14-2009, 06:42 PM   #5
Oldguard 7
CF Senior Member
Oldguard 7's Avatar
The service for my model year (79) calls to remove the two screws on the left side of the dash panel and pull it forward as well. I am going to have to change my light and dimmer switch. I'm sure it will be a pita.
Oldguard 7 is offline   Reply With Quote
Old 07-14-2009, 06:48 PM   #6
MN80Vette
CF Senior Member
MN80Vette's Avatar
I've had the headlight on my '80 in and out several times, including last weekend. I didn't do anything with the steering column or dash. I just removed the air duct and can reach the switch directly.
The first step is to disconnect the ground cable on your battery.
Remove the drivers seat so you can lay on your back and look up under the dash.
Disconnect your vacuum lines from the switch. (I don't have vacuum lines on my switch.) Then find the little spring loaded metal **** shaft release button by the vacuum connectors. (The arrow points to the button which is really on the bottom of the switch. The switch is upside down on the right.)
Pull the **** out as though you were turning your headlights on and press the button to release the shaft from the switch.
Use a small screw driver in the slots of the headlight switch nut to remove the nut from the switch.
Unplug the headlight connector block from the top of the switch.
MN80Vette is offline   Reply With Quote
Old 07-14-2009, 09:17 PM   #7
ramair_bryan
CF Senior Member
Default switch........removal.
thanks guys for the info. I freaked when i saw the dash coming rearward. Im going to go under the dash as mn discribed first. taking the seat out is a great idea as well. You guys replace these things frequently? gm' gotta get a better idea.......I just ordered one from an e-bay vender for $46 new......delivered. Let you know in a couple of days.......thanks.........bryan.:s eeya
Old 07-14-2009, 09:43 PM   #8
MN80Vette
CF Senior Member
MN80Vette's Avatar
Quote:
No, I don't replace the switch frequently. I replaced mine when I switched from vacuum to electric actuators. I had an electrical problem last weekend and removed the switch to check what was hot when. (Problem was an inline fuse I forgot about.) I also removed the switch for another in-dash electrical problem.
BTW, you may get by without removing the seat if you have a mirror and treble light on the floor to find the shaft button and see how to remove the connector block. You will definitely need to remove the air duct to get your hand up from the bottom. Pay attention to how it comes out and reverse the sequence when re-installing it.
Old 07-17-2009, 09:51 PM   #9
ramair_bryan
CF Senior Member
Default head light switch arrived.......
I'm going out to change the switch....., cover me....
Old 07-17-2009, 11:09 PM   #10
GS977
CF Senior Member
GS977's Avatar
where can i get a new headlight switch for my 82? its acting up.
GS977 is offline   Reply With Quote
Old 07-18-2009, 12:45 AM   #11
ramair_bryan
CF Senior Member
Quote:
Hi.......got mine on e-bay for cheep.
Old 07-18-2009, 01:24 AM   #12
RunningMan373
CF Senior Member
RunningMan373's Avatar
After the dash redesign, 80-81-82, the switch was accessible from below- just like a normal car.
RunningMan373 is offline   Reply With Quote
Old 07-18-2009, 06:03 PM   #13
ramair_bryan
CF Senior Member
Default Battery shorted.......
...........Ok....I'm dumb.........you guys arn't going to beleive this one. So all the tests and advice I got ( not you guys, guys I know). said the reason the big red wire on the alt burned (fuse link) was because I charged the battery @15 a for 4 hrs (took a nap, A viable excuse) All things pointed to a bad light switch.......okay I replaced it easly. how ever, connecting the bat term still smoked the link. One guy said, (not you guys, guy. I know) .........check battery for a short +.......- . so i did. It is now backwards from -........+. know wonder it burns the alt fuse link. God I'm dumb. I'm going to switch batterys with the camaro and see if it's all good.........You may be reading about me in the paper.......film at eleven...,,,,,bubba (not my real name). Hey running man......Did you go on the cruise to monterey with the rest?
Old 07-18-2009, 06:54 PM   #14
RunningMan373
CF Senior Member
If you reversed your battery, you may have allot of problems in the future. doesn't a 81 have a computer? i don't know the level of protections they designed into the car for this possibility, but it may not run.
Old 07-20-2009, 12:35 AM   #15
ramair_bryan
CF Senior Member
Default smoked.
Yea..........burned the ign mod in the dist as well. All else seems to operate ok. I'll give it a bath and buff it . red fades so fast around here. But this new buffer is so much better than the old one I was using.......Way faster settings and lighter too. .......back later........bryan.
Reload this Page head light switch removal
Tags
73, c2, c3, c4, c6, column, corvette, drop, headlight, hoses, removal, replacement, steering, switch, vacuum
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
