Throwout bearing Long or short ?
I have a 72 small block vette and am having clutch adjustment problems.What is the correct throwout bearing long or short for the oem setup?
Received 2,878 Likes
Hi TG,
It's part # 907963, 1 7/32" O. L..
There's only one part # from 64-72.
Regards,
Alan
Regards,
Alan
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Boy Alan, we got to get you a newer parts book. . . . .
GM p/n 907963 and p/n 907403 were both replaced by 908244, which was then replaced in the mid to early 90's by 15680264. This is still a good part number and it is the correct short bearing.
Willcox
Willcox
If your Vette has a bent cone diaphram spring on the clutch pressure plate as it should, you should use the short throw-out bearing. There are flat spring pressure plates out there and if your parts guy screwed up you may have one (used mainly for trucks and low performance applications.)
Hi Ernie,
I guess I should have said WAS....
I'm looking at a 1971 parts book!!!!
Sorry.
Regards
Alan
Sorry.
Regards
Alan
Former Vendor
Alan,
Email me your direct email address. . . WillcoxCustomerService@Willcoxcorvette.c om I may have a copy of this book! I'll have to check.
E
E
Former Vendor
Willcox
I did have the flywheel cut twice but they didn't cut much on the second cut. The mechanic picked up the clutch kit for me.
A Valeo kit that was suposed to be a stock replacement.
Linkage worn?
When I restored my 72 LT-1, I found that the linkage itself had worn.
The pin on the clutch pedal was a half moon instead of being round, the rod from the clutch pedal pin to the Z bar was oblong instead of round as was the rod from the Z bar to the clutch fork.
That explained my problems in not being able to adjust the clutch properly.
You may want to look at those pieces. I wound up installing a new pin (shoulder bolt welded to the clutch pedal) and filled the oblong holes with weld material and redrilled the holes. That was the cheapest way out.
