LT1 Wink Out
LT1 Wink Out
The title may be confusing, but, here's the problem . Many know I have a ' 76 that I installed a '94 LT1 in . Now, it has developed a problem that I can't figure . I'll be driving along, and the car will just die . It's only a split second, but, scares the hell out of me ! I haven't checked anything yet, as I figured I'd run it past the more knowledgable people on here first . When I say die, I mean EVERYTHING ! I know when it happens as the radio cuts out and that's my tell . It comes right back,( the power ) but, hell, it shouldn't do it at all . Any ideas, solutions are greatly appreciated !
Firewall connector, behind the fuse panel, bad connection or loose retaining bolt, I bet odds.....
had a crazy thing like that happen to me at a airport one night, used a jumper cable and some clip leads to get the car home...
talk about lucky, there was no one around, last flight in....
I had exactly the same thing happen last week. Loosened the ignition and wiggled it and got power again. Lasted for another week of holidays and 1000 miles. Then died again when getting fuel. Pulled center console out and found that the ignition plug had come undone. Plugged it back in and not a problem since.
shmoky
shmoky
Fuse block connection problem or ground wire/connection problem. Don't forget to check your battery cables on both ends.
I had this exact problem with my one owner 80 vette. The whole electrical system would stop and I mean everything would black out while running down the road and then suddenly, all would resume as normal. One day the vette suddenly died and rolled to a halt. Dead like it had no battery in it. I lifted the hood and began checking wires. When I grabbed the fusible link wires(by the firewall down to the starter), the underhood light came on. I replaced the fusible link wires with heavy-duty wiring. They were all burnt and corroded from header heat. I've had no problems since. I hope that this helps.
Ok, color me " not too bright " :o . Started looking for the problem today . When under the hood, checked connections at the computer , engine , etc . THEN, I went to the battery , before trying to squeeze under the dash . Guess what ! The POSITIVE clamp was LOOSE !! The boneheads who did the body restoration evidently ' forgot ' to tighten it ! I could almost spin it around !!! I'ts too early to tell if that was it, as I said, it just dies at will . But, I'll bet every $ I have that was it ! Doubtful it has anything to do with the fluctuating radio whine , but, I hope it cured the shorting problem . Many many thanks to all that offered suggestions !!!
