Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-03-2009, 12:03 AM   #1
xkeots
CF Senior Member
Default 1977 vette snapped rear wheel stud
Hi All,
I was replacing with new acorn nuts on my rims, after I had new tyres put on. I sadly found out that they cross threaded one of the rear studs and it snapped off as I was removing the last one.
Do they just tap out and I can get it in from the back of the wheel hub?
Jack
xkeots is offline   Reply With Quote
Old 07-03-2009, 12:51 AM   #2
Vette80regon
CF Senior Member
Vette80regon's Avatar
NOOOOOO!!! You too!?!?!
This just happened to me minutes ago.
But, I STRIPPED my stud. Didn't snap off. Stripped the threads.... SH*T!
mine was when I was re-torqueing on the torque wrench on my new race wheels....
sorry brother. I'm here with you.
Vette80regon is offline   Reply With Quote
Old 07-03-2009, 10:35 AM   #3
markids77
CF Senior Member
You will have to remove the disc and emergency brake shoes, then you will have the devil of a time pressing the new stud in unless you also remove the stub axle. No fun to be sure!
markids77 is offline   Reply With Quote
Old 07-03-2009, 11:21 AM   #4
KapsSA
CF Senior Member
KapsSA's Avatar
I was able to punch a broken one out after removing the rotor. If it's just stripped, cut it off with a cutting wheel, otherwise you'll have a heck of a time getting it past the backing plate!
You can unbolt the caliper and if you pull the clip from the rubber hose it will give you a little play to move the caliper with the line attached up out of the way and hang it up with a wire. Make sure you slip something between the pads as you slip it up off the rotor. I use a socket.
I then took my new stud and ground a slight chamfer on one side of the head. Putting it up to the stud hole in the flange with the ground in bevel against the backing plate I gave it a slight whack with a hammer and it popped right in. From below. Enough give in the backing plate, nothing bent at all. Greased up a couple of washers and slipped them over the stud and pulled it in with a regular lugnut, flat face against the washers.
edit....I also removed the parking brake adjuster to gain access.
KapsSA is offline   Reply With Quote
Old 07-03-2009, 11:40 AM   #5
autoist
CF Senior Member
I've also got one snapped off...luckily mine's down to stripped chassis & everything is coming apart...tell me how you finally solve the issue, please.
autoist is offline   Reply With Quote
Old 07-03-2009, 03:21 PM   #6
Red 71
CF Senior Member
Red 71's Avatar
Location: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
As long as everybody can picture what the purpose was of grinding the bevel I think you pretty well covered it! I have done it exactly as you described.
Red 71 is offline   Reply With Quote
Old 07-03-2009, 03:33 PM   #7
midyearvette
CF Senior Member
Support Corvetteforum!
midyearvette's Avatar
did you oil the threads??
midyearvette is offline   Reply With Quote
Old 07-03-2009, 05:10 PM   #8
GTR1999
CF Senior Member
I found this problem with the new lug nuts on the market. The threads and steel roll and lock up the nut. Sometimes this happens so fast with an inpact gun it shears off the stud. Not sure if GM still sells lug nuts but be careful if you use those chain store or NAPA nuts.
GTR1999 is offline   Reply With Quote
Old 07-03-2009, 07:01 PM   #9
Vette80regon
CF Senior Member
no, I didn't
my dad used to oil all his lugnuts on the farm etc... I never saw the use for that. Is this the culprit?
Old 07-03-2009, 07:09 PM   #10
midyearvette
CF Senior Member
no, I didn't
no actually quite the opposite..usually if someone oils the lug threads and tries to torque to spec, they will in advertenly roll or strip the threads......whenever you use an oil, you must reduce torque specs...they should go on clean and dry.....if you tried 100 lbs...i always thought it too much...i go 85 lbs....sorry bout your luck, great looking wheels tho!!.....
Old 07-03-2009, 09:15 PM   #11
KapsSA
CF Senior Member
KapsSA's Avatar
Quote:
The ground in bevel is to gain a tiny bit of room and to keep what would otherwise be a blunt edge from digging into the backing plate.
Old 07-05-2009, 02:00 PM   #12
xkeots
CF Senior Member
I bought new tires. The nuts that came with the mags were rusted but fine. The f%$%^&g mechanic, when he replaced the wheels cross threaded the lug nut and I snapped one trying to remove it. I bought a new set of chrome acorn nuts and as I was replacing them, on the last one it was cross threaded. I am ticked off as I asked the mechanic to use a hand bar to tighten not an impact wrench. If he did he never would have cross threaded it.
Jack
Old 07-05-2009, 03:23 PM   #13
KevinK
CF Senior Member
KevinK's Avatar
I recently snapped 3 of my lug nuts on the passenger side rear wheel, but for entirely different reasons, lol.
If you need any advise on how to replace them with ARPs, let me know.
KevinK is offline   Reply With Quote
Old 07-06-2009, 12:03 PM   #14
xkeots
CF Senior Member
What's ARP's?
I know that when you hit 50 you get AARP.
Jack
Reload this Page 1977 vette snapped rear wheel stud
Tags
c3, corvette, stud, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
