Insde door opening unit/rods
I removed the door panel to replaced the door opening unit . The
rods that connect to it were loaded with grease . Everything the rods
were connected to the same , loaded with hard dry grease , it was no wonder the door was hard to open . My question . . . do you used grease
on areas where the rods connects ? Any kind of lube at all or not any.
