Who needs timing advance???
Hi
So I just got my vette back from the mechanic. He was doing a ton of things to it, trying to get the new crate engine to run fine. I'm sure he reads this forum, so he's is probably reading this along with all of you.
To my surprise, he had tuned it so that there would be no mechanical or vacuum advance.
Thus, the advance is now always at 36 degrees all the time at all RPM's.
What are the pros and cons of this?
THanks
THanks
Read the sticky post on the top of this page. It will explain everything (or at least get you well on your way). I used the advice and my car has never run better. http://forums.corvetteforum.com/c3-t...long-post.html
IMHO, If what you are saying is correct I'd take my car elsewhere in a heartbeat.
RUNNN, Forrest! (to a new mechanic)
Hi
THanks
THanks
Hi
THanks
THanks
Is your car a race car? Or a very radical street car, that doubles as drag
car? This is a common setup for drag car. But we all don't drive race cars on the street.
I run my car 35 deg. all in. But with a 20 deg. start retard. If your running
a mild motor, less than 500 H.P. iron heads on pump gas, this is not the
setup.
setup.
I have to assume you misunderstood - but if not, your "mechanic" needs to seek other employment.
If he's been cranking on a new engine without it starting, I hope you're preoiling the hell out of it. A new engine should fire immediately if everything's right - and it's worth the time required to get everything right.
setup.
setup.
No way you could start the car. You'd get kick-back.
No way one setting (36*) is optimal for all street driving conditions. My cars typically have 14-16 degrees initial, 36 total mechanical, and another 16 from the vacuum advance can, meaning I could have over 52 degrees timing,..highway cruising for instance.
Agree,..find a mechanic who understands timing.
Hello All
Yes, I double checked with the mechanic, and he locked advance on the distributor so it is always at 36 degrees advance.
My engine is a 383 crate with aluminum heads and roller rockers, rated at 475hp. Dont know if it makes a difference in deciding to lock the advance on the distributor. It's not going to be used only at the track though. Most of the time it will be street driven.
Could there be other problems besides being hard to start?
The car starts up fine though. Is the starting the main concern?
Received 1,252 Likes
Hello All
Yes, I double checked with the mechanic, and he locked the distributor so it is always at 36. Dont know if it makes a difference in deciding to lock the differential. It's not going to be used only at the track though. Most of the time it will be street driven.
I think a distributor locked at 36° for a street car is a big mistake, except if you drive it always as a drag race car.
Can work well at WOT, but certainly not the best setup in traffic...
Even no vacuum advance is not a good idea either, for the same reasons, plus mpg...
