BBC Aluminum vs Iron Head Question
Just curious on the average what is the wieght savings between a set of BBC aluminum heads vs a set of BBC iron heads? While I have the 509 out of my 69 I was thinking about replacing the cast iron Merlin II rectangle port heads with a set of Merlin III aluminum heads. Just was wondering how much wieght that would knock off the front end?
Fully assembled iron 308 rectangle port, 70 lbs X 2 = 140
Fully assembled 308 pro 1 aluminum, 29 lbs X 2 = 58 lbs
This is just looking at what dart shows on there web site as weight
for there heads.
for there heads.
Received 1,900 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
And if you're buying heads....I'd pick a better set. You can easily beat the Merlin's these days.
JIM
JIM
look at it this way. i replaced the iron heads with al on my 454.
i had to get help lifting them up off of the car.
the al ones i could lift onto the block with one hand
