Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-26-2009, 08:42 PM   #1
mark79,80
CF Senior Member
mark79,80's Avatar
Default Riveted compared to bonded parking brake shoes
About 5 years ago I purchased three sets of riveted parking brake
shoes from a leading corvette parts vendor and had them installed
by a shop in a 1979 and two 1980's. In the final adjustment
of the shoes the technician put the cars in drive and
raised the handle to check for drag. One shoe cracked
across two rivets and the broken half wedged against the rotor.
Realized that this was too aggressive
a method to check for drag, but if you needed to use the parking
brake in an emergency the shoes should not crack.
Recently I removed the rotors on another of the cars to check
for drag when readjusting the parking brakes. I noticed another
shoe was cracked across two rivets. The shoe did not have any
wear marks to indicate it was dragging. Shoe looked new in
terms of thickness.
I noticed that some of the shoes being sold are bonded instead of
riveted. Thinking that the bonded ones might be less likely to crack
and a better choice?
mark79,80 is offline   Reply With Quote
Old 05-26-2009, 08:55 PM   #2
calwldlife
CF Senior Member
calwldlife's Avatar
Curious.
Sounds more like the shoes have the wrong arc.
I have always used bonded in cars with drum brakes.
calwldlife is offline   Reply With Quote
Old 05-26-2009, 09:00 PM   #3
joewill
CF Senior Member
joewill's Avatar
yes bonded will not start grinding into the drum until they are almost totally worn out.. unlike riveted... but who has ever worn out their vette emergency brakes? the parts crumble due to corrosion long before the break shoes wear out...
joewill is offline   Reply With Quote
Old 05-26-2009, 09:02 PM   #4
...Roger...
CF Senior Member
...Roger...'s Avatar
I dont think I've ever seen any bonded shoes. I used to reline them with rivet linings.
...Roger... is offline   Reply With Quote
Reload this Page Riveted compared to bonded parking brake shoes
Tags
bonded, brake, c3, corvette, cracking, ebrake, forum, parking, riveted, rivited, shoe, shoes
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
