Starter or safety neutral switch???
i need more opinion before i change my starter. How will i now if my safety neutral switch needs to be replaced.
my car always starts first in the morning. it only wont start again after i drive the car.
i just want to make sure its not the safety neutral switch. Do u guys know how will i find out if my safety neutral switch is bad???????
thanks in advance.....
I had the problem driving it home the 1000 miles after purchase. Couldn't even jump it. Hour later it started right up.
I simply disconnected the battery cables, made sure things were clean, and reconnected them. No problems in 5 years since.
Make sure your ground cable connection right below the battery box is clean and tight.
Replacing the starter may fix things simply because you're disconnecting and reconnecting the cables, not because you have a new starter.
Received 1,254 Likes
Sounds like the problem the previous owner had with my white79.
The only way to know for sure that the neutral start switch is operating correctly is to 'dig' down to it and check for continuity when moving the shifter through the ranges (engine OFF). If working properly, it should make connection anywhere in the neutral range and in Park...but should not show continuity in any other range. The NSS and the starter solenoid are your most likely 'culprits'...but a bad wiring connection or a starter with worn-out brushes could also be the problem.
I had a '69 El Dorado that did the same thing. Turns out the carb was bad causing raw gas to enter the cylinders and hydrolock when hot and couldn't turn over. When the engine cooled down and the gas evaporated the car would start right up.
Do all the others have suggested and take the starter down to Autozone and have them check it out for you.
Cruising
I have had this problem, too. From what I have been told, it is a common problem...it is the starter getting over-heated next to the exhaust manifold (or header). You have to wait until it cools enough before it will start again. Solution...from what I am told, a new starter will help if you are still running an older or original starter...and/or installing a thermal cover around the starter to protect it from the heat. I, myself, plan on doing both...getting a new starter and then wrapping it in the thermal cover.
hope this helps...
hope this helps...
Run a temporary setup like this drawing and the next time the car wont start watch the light-if it lights then like Pete says replace the solenoid-if the light doesnt light then you can look at the neutral safety switch,and other PURPLE wire connections.
Excellent idea! If the bulb lights, you know that the solenoid is getting the 12vdc signal to it. If the starter doesn't turn over, it would have to be the starter solenoid (or, less likely, the starter and/or cables).
a sheild is better than a wrap,
the sheild allows airflow, the wrap also holds the heat in a starter.
You never wrap an electric motor/starter.
