dist. vacuum advance question
after putting a new distributor vacuum advance on do i need to adjust anything? thanks.
Only that it really works! {Lots of 'new' parts don't, anymore.} I would put the timing light on it just to check.
Location: Las Vegas - Just stop perpetuating myths please.
U mean u replaced the vac can?
Now u know your eng idle vac and WOT (next best thing) vac. U need a vac can that has no adv at WOT and full adv at your normal idle rpm. U can check any installed vac can by taking off the dist cap and connecting a "Mighty Vac" brake bleeder and watch where the can starts to pull in (WOT) and and where full adv (idle) is on the "Mighty Vac" gauge.
That's as easy as i can make it for u. Now u can shop for the right vac can yourself.
Hope this helps,
cardo0
There is no manifold vacuum at WOT.
Adjustable cans are like anything else - just buy a good name brand unit. I have used several and have never had a problem. I have the Accel on my '79. It's been there for about a year on a car that I drive 60 miles everyday. I have the Crane unit on a '77 Pontiac 400 - it's been there since '03 and has over 50,000 miles on it and still works just fine - and I have the Proform (came on the dist) on a '72 Chev K20 - again no problems in over 3 years of occasional use.
Really? Then how does air (and fuel) move through the carburetor and into the combustion cylinder? Just PFM?
Someone or more than one here needs to go out and measure thier eng vac with the secoundaries open.
cardo0
This thread isn't just hijacked its trashed. Too many posting info they need to prove to them selfves instead of expecting others explain the very basics to them.
cardo0
