Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-29-2009, 12:57 PM   #1
CoreyCorvette76
Junior Member
Default 76 steering column rebuild?
I just bought a 1976 vette and the steering column is a mess... all the parts are there, but i think it needs to be rebuilt. I was hoping i could find a forum of someone who already asked this question of how to rebuild it, but i didnt have too much luck. I am only 19 and i dont really have anything to compare it to, to rebuild it. Maybe some one has pictures of their rebuild or some tips on how to start. Thanks!
Click the image to open in full size.
CoreyCorvette76 is offline   Reply With Quote
Old 03-29-2009, 04:22 PM   #2
noonie
CF Senior Member
noonie's Avatar
Here is a link to all the instructions.
http://jimshea.corvettefaq.com/?page_id=4
Also, your gear and rack gear are not meshed properly and the spring is not correct
noonie is offline   Reply With Quote
Old 03-29-2009, 04:52 PM   #3
71406
CF Senior Member
71406's Avatar
Looks like you have a tilt column which is a nice feature, but they could be a little more expensive to rebuild if the pivot is worn or damaged. If its the original column from a 76 you should be aware that you will be limited to choice of steering wheels. If I remember correctly, GM used the same wheel that came on other GM products like the Vega and you cannot interchange other steering wheels from other year corvettes. You may want to verify before sinking big bucks into the column.
If you're on a budget and you don't care about the tilt feature you could always sell the one you have (someone may want this feature) and buy a complete standard column from a 69 - 75 corvette. I think they are a direct fit. Again you should research. As suggested above, Jim Shea's site is a great place to learn about your column.
71406 is offline   Reply With Quote
Old 03-29-2009, 07:02 PM   #4
72LS1Vette
CF Senior Member
72LS1Vette's Avatar
IMO the standard columns suck. The steering wheel is too close to the driver and ingress/egress is more difficult. It's a good position for racing but for daily driving it's too retro for my taste. The later model (77+) tilt/tele columns position the wheel a few inches closer to the dash and provide a much more comfortable driving position. If you are going to the trouble of replacing the column I would try to find a later model tilt/tele.
__________________
72 Ontario Orange Coupe. 2001 LS1 - LS6 block & Intake, Thunder Racing Cam, Ported heads and Throttle Body, Meziere electric water pump, Hooker Shorty Headers, 2001 T56 6-speed trans, VB&P Street & Slalom suspension, Magnaflow exhaust, DeWitt's radiator, SPAL fan, C5 power seats, Borgeson steering conversion. Future mods: HydoBoost, floor mats.
72LS1Vette is offline   Reply With Quote
Old 03-29-2009, 07:37 PM   #5
noonie
CF Senior Member
noonie's Avatar
I fail to see anything there or by the OP's description that suggests a replacement of the column.
Print out the papers and have at it.
It may well be that someone had been in there before and assembled it incorrectly, with no new parts necessary at all.
Old 03-29-2009, 09:42 PM   #6
CoreyCorvette76
Junior Member
I will follow the instructions... i have all the pieces from the owner... they are just all scattered in a box. Appreciate the help!
Old 03-29-2009, 10:42 PM   #7
Jim Shea
CF Senior Member
Support Corvetteforum!
Jim Shea's Avatar
Your pictures are worth a 1000 words. I would suggest that you try and lay out the loose parts from the box and take several pictures of them.
Also download this blowup pic of the steering column.
http://jimshea.corvettefaq.com/wp-co...owup03FE04.doc
Eventually you will need this steering wheel and horn parts pic.
http://jimshea.corvettefaq.com/wp-co...&HornParts.doc
This way we can be talking about a particular part in a particular picture and relate it to the blowups and how it goes together.
Jim
Jim Shea is offline   Reply With Quote
Old 03-30-2009, 10:56 AM   #8
CoreyCorvette76
Junior Member
This weekend i will get at it and hopefully notice that i HAVE all of the parts... i appreciate all the help and ill keep you'll updated with success... hopefully.
Old 03-30-2009, 04:14 PM   #9
dobroman2001
CF Senior Member
dobroman2001's Avatar
Quote:
Here's a link that may help...
http://blog.scottsvettetalk.com/2008...n-rebuild.aspx
dobroman2001 is offline   Reply With Quote
Old 03-30-2009, 04:40 PM   #10
markdtn
CF Senior Member
markdtn's Avatar
... If its the original column from a 76 you should be aware that you will be limited to choice of steering wheels. If I remember correctly, GM used the same wheel that came on other GM products like the Vega and you cannot interchange other steering wheels from other year corvettes. You may want to verify before sinking big bucks into the column....
Not exactly true. The '76 has a unique steering wheel, but if you swap the hub it is the same as any other 69-75 T&T column.
markdtn is offline   Reply With Quote
Old 03-30-2009, 04:51 PM   #11
dobroman2001
CF Senior Member
Quote:
And here's a link for that!!
http://s189.photobucket.com/albums/z...eel%20removal/
Old 03-30-2009, 06:32 PM   #12
KevinK
CF Senior Member
KevinK's Avatar
Quote:
Originally Posted by dobroman2001 View Post
Where did you get the hub for that new wheel?
I went out and bought a steering wheel from a 78, not thinking at all....
And can't put it on.
KevinK is offline   Reply With Quote
Old 03-30-2009, 09:16 PM   #13
dobroman2001
CF Senior Member
Zip #SC-413
http://s189.photobucket.com/albums/z...lchange006.jpg
Reload this Page 76 steering column rebuild?
Tags
1976, 75, 76, c3, column, corvette, gm, put, rebuild, rebuilt, steering, tele, tilt, vega, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
