1978 speedometer needle replacement
Old 03-28-2009, 07:01 PM
blctalon
blctalon's Avatar
Default 1978 speedometer needle replacement
I'm trying to get my speedometer needle to read zero once it's installed. I seem to recall reading a thread on here a while back where someone explained the procedure but I can't find it via search. Is there anything special to getting this thing aligned on the stud so that it read correctly?
Old 03-28-2009, 07:30 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It’s easy to install the needle. Gently place the needle at about 60 mph and turn it counter clock wise while pushing downward on the center area. As you get closer to 0 just push a little harder. If you don’t get it right the first time try again. You remove the needle in the same manner only instead of pushing inward you pull outward.
Willcox
Old 03-30-2009, 09:21 AM
blctalon
blctalon's Avatar
Ok, I'll give that a shot. I think I had it at about 45-50 when I pushed it on but I better take then lens off and try it again. Once I get this on and the vacuum issue settled I'll be putting in your carpet next willcox.
Old 06-05-2010, 07:46 AM
C3 4ME
C3 4ME's Avatar
Just to be clear, to remove the old needle, you should be pulling on the needle as you turn it clockwise from 0 to somewhere about 60?
Old 06-17-2010, 08:48 PM
C3 4ME
C3 4ME's Avatar
ttt. anyone? anyone? Bueller?
Old 07-17-2010, 07:29 PM
Drawmain
Drawmain's Avatar
Well, I just broke the needle shaft trying to pull mine off. Now what??
Old 07-17-2010, 07:44 PM
72LS1Vette
72LS1Vette's Avatar
You probably need to buy a used speedometer and swap out the piece that holds the needle shaft.
Rick B.
Old 07-17-2010, 08:18 PM
Drawmain
Drawmain's Avatar
Yep, got one on order
sheesh, lol
Old 11-19-2012, 05:19 PM
worship79
Support Corvetteforum!
worship79's Avatar
sheesh, lol
Were you succesful? Same problem here
Old 11-19-2012, 07:45 PM
Drawmain
Drawmain's Avatar
I bought a 140 MPH unit from a vendor and just swapped them out.
Old 11-20-2012, 06:49 AM
myko
myko's Avatar
I did the same thing. I was able to glue the shaft and make it work until I got a new one. When you got the 140MPH unit did you have to swap out the driven gear to get it to read correct? I just put a 120MPH face on my old unit thinking that I could get a larger gear to make it correct but the TH350 doesn't have a gear with enough teeth to make it correct. Haven't gotten around to getting it just right yet
Old 11-20-2012, 11:12 AM
Drawmain
Drawmain's Avatar
I ordered a complete unit that was correct for my 82 but re calibrated for the 140 mph face so it was just plug and play for me.
Old 11-24-2012, 08:01 AM
worship79
worship79's Avatar
Yeah, looks like the wisest thing to do apart from sending it in for repair.
To 1978 speedometer needle replacement
Quick Reply: 1978 speedometer needle replacement
