Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2009, 08:35 PM   #1
rudolph schenker
CF Senior Member
Support Corvetteforum!
rudolph schenker's Avatar
Default Body mounts replaced with pics!
I have been procrastinating this 'littlle' project for some time. As I have read other accounts and seen pics I prepared for the worse!
Some carnage from the removal. I took a sawzall to the #4 and#5 mounts.
Click the image to open in full size.
One doesn't see this view very often...
New mounts (rubber) ready to go...
I did one sid at a time using a floor jack and a 2x6 for support when lifting the body. Here are some finished pics...
Not a very fun job, but it was time to replace those mounts as one can see. I'm glad it's over!!
rudolph schenker is offline   Reply With Quote
Old 03-03-2009, 08:43 PM   #2
CA-Legal-Vette
CF Senior Member
CA-Legal-Vette's Avatar
Looks great Mark. Nice job.
I've been putting off the same job for years. Don't know if the sawzall will do it. May need dynamite.
CA-Legal-Vette is offline   Reply With Quote
Old 03-03-2009, 08:53 PM   #3
Artsvette73
CF Senior Member
Artsvette73's Avatar
Good for another 30 plus years
Artsvette73 is offline   Reply With Quote
Old 03-03-2009, 09:00 PM   #4
Glassbowtie77
CF Senior Member
Glassbowtie77's Avatar
I've been putting off doing mine also. I have to admit I'm a little aprehensive about doing it. Don't want to start something that I may not be able to finish. I've putting that off and rebuilding my trailing arms also.
__________________
'77 L48 Coupe
Edelbrock Performer 2101, Hooker Super Comp Ceramic Coated Sidepipe Headers w/ 4" Sidepipes and Hooker Max Flow mufflers, Proform Hei Distributor, Stewart Stage 2 Water Pump, Accel Coil & Accel 8mm Superstock Wires, 100 amp Alternator, Cloyes Street True Roller Timing Chain, VB&P 550lb springs, VB&P 360lb Monospring, VB&P Smart Struts, VB&P 3/4" Rear Sway Bar, Bilstein Sport Shocks, Firestone Firehawk Indy 500's 255/60-15's, TH350, 355 rear.
Glassbowtie77 is offline   Reply With Quote
Old 03-03-2009, 09:06 PM   #5
69427
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
Quote:
I first put the rubber mounts in my '69 in 1975. I just replaced them again this week. They could have gone a few more years, but I had the car apart anyway.
69427 is offline   Reply With Quote
Old 03-03-2009, 10:05 PM   #6
spikebot 81
CF Senior Member
spikebot 81's Avatar
Well I got real lucky. Just finished all 8 mounts on saturday. No rust issues no broken bolts or frozen cage nuts. 6 hours start to finish
spikebot 81 is offline   Reply With Quote
Old 03-03-2009, 11:32 PM   #7
OzzyTom
CF Senior Member
OzzyTom's Avatar
So, is this a body off job....
or can you get to those mounts without lifting the body right off?
Rudi.... Has your ride height changed with the new mounts?
what about issues with panel alignments/gaps ....
I've heard horror stories of misaligning doors, bonnet and body panels due to different settling on the mounts ????
I keep putting my mount replacement off.....
OzzyTom is offline   Reply With Quote
Old 03-04-2009, 12:09 AM   #8
rudolph schenker
CF Senior Member
I have not measured the ride height. I watched the new rubber mounts compress as I tightened the bolts, just by eye-balling it they appeared to about the same height as the old ones I removed. I also kept track of how many shims were at each mount and replaced them.
I kept the #2 and #3 mounts in (but loose) and while doing the passenger side and the #6 and #7 in while doing the driver side to help with alignment. I only raised each side approx. 4 inches (doing one side at a time). As far as I can tell everything is the same (no uneven gaps etc).
Old 03-04-2009, 01:24 AM   #9
scottyp99
CF Senior Member
scottyp99's Avatar
Wow, same boat, I kinda need to do mine, and I guess it's best to do it before you REALLY need to do it, if ya know what I mean. Musta been tough fighting off the "while-I'm-at-it's" with that kinda job.
Scott
scottyp99 is offline   Reply With Quote
Old 03-04-2009, 02:01 AM   #10
ED69ray
CF Senior Member
ED69ray's Avatar
Quote:
that happened to me - opened up a real Pandora's box on my '69. I had some rust issues to begin with - thats why the body was pulled to begin with.
both left and right #3 mounts were rotten - both at the frame and on the body. As a result both lower door rails (#2 and #3 mounts) are being replaced.
ED69ray is offline   Reply With Quote
Old 03-04-2009, 03:44 AM   #11
Grumpy 427
CF Senior Member
Grumpy 427's Avatar
Send a message via MSN to Grumpy 427
I just ordered a set this week.I will wait till i get the motor out of the car, i have the entire drive train out anyway so this will make life a bit easier i hope?
Grumpy 427 is offline   Reply With Quote
Old 03-04-2009, 10:03 AM   #12
20mercury
CF Senior Member
20mercury's Avatar
Default Good job, I need to do the same on 76.
Good job, I need to do the same on 76. I also need to paint the frame, which it looks like you might could almost scrape a little and dab rust converter in the space on top.
It would be great if you could post some directions on how you did this. For example do you need to remove the front and rear bumper (assume this is an 82 from your profile)? and where & how do you jack to avoid cracking the fiberglass.
One other question, my fuel line is spliced where it rusted out above gusset in front of RR tire. Do you think you could install this fuel line at the same time?
Much thanks.
20mercury is offline   Reply With Quote
Old 03-04-2009, 11:07 AM   #13
rudolph schenker
CF Senior Member
Much thanks.
Good questions. Yes, I did this on my 82.
Things I removed or loosened include
1. Front bumper, pay attention to where the front brace bolts to the body at the nose.
2. Unbolted the steering box from the frame. Left it coupled to the steering column.
3. Unbolted the master cylinder from the vacuum assist and supported it.
4. Removed the grounding strap by the #1 mount.
5. Unplugged the brake sensor from the brake line distribution block.
6. Removed the side trim on both sides. This is where I placed the 2x6 along the entire length for jacking.
With my car it was not necessary to remove the rear bumper.
I only jacked the body up 4 inches and did one side at a time. As you can see from the pics I used a little POR 15 on the mounts and tops of the frame rails (no pics of finished frame rails).
Cleaned up the headlight sub-assemblies and front brace while I was there.
Hope this helps a little!!
Old 03-04-2009, 11:08 AM   #14
ED69ray
CF Senior Member
ED69ray's Avatar
should not have to worry about any height differences with a chrome bumper car - the '68-'72 body mounts are solid - no rubber. I just ordered a kit for my '69 model
Old 03-04-2009, 11:29 AM   #15
hugie82
CF Senior Member
Nice Detail Rudolf!!! I wish you did that last fall. I searched every website for picks and info on are late model C3s with no luck. Everyone was doing an early 70s so I paid a guy to do mine for about $500. I wish I did do it so I could have touch up a lot of stuff like you. This thread should be a sticky or in a DYI site. Great Job
hugie82 is offline   Reply With Quote
Old 03-04-2009, 11:51 AM   #16
rudolph schenker
CF Senior Member
Quote:
Thanks! It has been satisfying to clean up that front end! I'm going to paint it in a month since I have most of it apart now.
Old 03-04-2009, 02:35 PM   #17
20mercury
CF Senior Member
20mercury's Avatar
Default Much, Much thanks!
Much, Much thanks this is super info and a super writeup.
Your car looks great!
Old 03-05-2009, 07:54 AM   #18
GTR1999
CF Senior Member
Very nice job,did you put some never seize on those bolts? Not that you're going to have to replace them for a very LONG time. That's going to be a great cruising car!
GTR1999 is offline   Reply With Quote
Old 03-05-2009, 10:01 AM   #19
Vetteaddiction
CF Senior Member
Vetteaddiction's Avatar
This is one of the best threads I've seen in a long time. Awesome job and great pictures! Thanks for going back through with the step by step instructions.
Just have one question - How did you get the body mounts clean before the Por 15? Wire brush?
Thanks again, Chris
Vetteaddiction is offline   Reply With Quote
Old 03-05-2009, 10:26 AM   #20
spedaleden
CF Senior Member
spedaleden's Avatar
Mark,
Very nice work. How many swear words where used?
A couple of bolts loosened and some wire harnesses and fuel lines disconnected and you could of taken the body off. On a scale of 1 to 10 what was difficulty? From your pics your car doesn't look like it needs paint, I guess it is the mystery of pictures.
Again nice work
spedaleden is offline   Reply With Quote
Reload this Page Body mounts replaced with pics!
Tags
1981, 4, 68, 76, body, c2, c3, corvette, forum, frame, location, mount, mounts, rear, replace, shims
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is this Rust???? RedAudiomobile C3 Tech/Performance 20 07-19-2004 08:37 AM
Body mount project started redwingvette C3 Tech/Performance 30 07-27-2003 09:54 AM
Just took body off - need advice of the experienced NHvette C3 Tech/Performance 27 06-25-2002 04:00 PM
The Body mounts are off now!!! 454Big C3 Tech/Performance 13 01-20-2002 04:21 PM
Pics of my 77...what a mess! I need opinions daniel77350 C3 Tech/Performance 12 08-12-2001 10:06 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
