73 just got it now it won't start!
4th Gear
I just traded for my first vette. it's a 73 with the 5.7 350 and a turbo 400 auto trans. i'm very new to this and i need help because shortly after driving it home, it began dying on me. at first it died when i came to a stop sign, but then it started dying even when i was cruising. i called the guy who sold it to me, and he came out to help when i could restart it and i was on the side of the road. he replaced the fuel filter and flushed some rusty water out of the hose saying that was the problem. after he did that it ran great, but about 3 miles later after we went on our way, the problem came back! it looks like the carb isn't opening up right, but like i said i'm new to this thing so i'm not sure. now i can't even get the thing running at all.
it appears like the problem lies in the fuel system, but i don't know exactly where.
does anyone have any idea what is causing this?
thanks
thanks
thanks
thanks
You should be able to shine a flashlight into the tank through the filler neck and see what the condition of the bottom of the tank is.
You're probably going to have to replace the tank and the in tank filter.
Dont get discouraged yet there are many problems to come.
like said about check the fuel tank for crud in the bottom. Check the fuel filter again. If it has a bunch of trash in it then the fuel tank needs to be cleaned. If the car sat for a long period of time the fuel may have deteriorated causing some of the crud in the tank. You can try to vaccum out the crud, but a tankl removal and flushing is really required.
This will be the first of many things to do, but it is worth.
Roger
Roger
Roger
Roger
car wont start
Drop the spare tire carrier, depending on how much is in the tank, get some 5 gal. containers and pull the fuel line off and drain the tank. Depending on what your tank looks like inside and out you may want to replace it. If you have small hands it may fit in to the tank and you can clean up the rest with a lint free shop cloth - my hand fit with some scrapes.. If it looks O.K. on the inside put some gas back in, then pull the line off the fuel filter and put the line in a jar and crank the car over to clean out the fuel line. I would then replace the filter. If the previous owner flushed out "rusty water" I would consider rebuilding / replacing your carb.
St. Jude Donor '09
That's the ticket
