How to change 200R4 drive gear?
Hello
I need to change the drive gear inside the 200R4 because I change the rear end ratio, I need some guide lines and pictures to know How to do it.
Avner
Avner
BAd news, bro. The speedo drive gear is on the output shaft and that's the first part that goes in when you rebuild a 200-4R. And that trans does not have a removeable tailhousing.
Bottom line is you have to tear the tranny down completely to replace the drive gear.
An option is getting a ratio adapter from some vendor.
So what to do?
There is anyone here that changed the drive gear inside the 200R4?
I have in my hand the correct drive gear & driven gear for the new rear end ratio.
Avner
Avner
1 Remove the speedo cable and driven gear from the housing
2 drain fluid and remove the pan
3 the governor cover has 4-13 mm bolts remove them and the cover
4 remove the snap ring on the governor shaft and remove the gear
Reverse order to instal.
Note: You should replace the governor cover gasket if it is cracked or brokenl
Below is a pic of the governor. The thin gear drives off the out put shaft. The larger gear is the drive gear for the speedo driven gear
You don't have to go as deep as my pic shows just the cover that you see in the back ground above the green gear.
Artsvette73 & mdbelanger
Thanks for the guid lines an pic'
My 200R4 it's new still in the box.
I will change the drive gear I think I can do it but it will need to wait a bit because now I'm working on the engine an the staff arund it to be redy for first time.
You can see in this link some prograsse that I did.
http://forums.corvetteforum.com/c3-g...-pictures.html
Avner
Ok I changed the drive & driven gear as Artsvette73 & mdbelanger explain & it was easy to do.
Avner
