4 speed side cover seals
Has anyone replaced shift shaft seals in side cover on BW 4 speed without taking the cover of when the trans is in the car.
I guess that would be possible using a sheetmetal screw and washer to pry it out but, I would take off the side cover to do this job. You would risk damaging the side cover by running screws into the seal while in the housing.
I did mine not too long ago. I removed the side cover, it made things much easer. I have some pics. here. http://picasaweb.google.com/Walllparty/78Transmission#
Thanks for the pics. I quess it would be easier to remove the cover to replace seals.What is that sheet metal piece is it a gauge to adjust the shifter? I been to simpsonville once my daughter played fastpitch there nice place.
