Dart Pro 1 Platinum flow numbers ?
Old 01-24-2009, 06:15 PM
sting66cp
sting66cp's Avatar
Default Dart Pro 1 Platinum flow numbers ?
I'm looking for flow numbers for the 180 and 200 Pro 1 Platinum heads, their web site seems to only have flow numbers for .500 lift?
Old 01-24-2009, 06:26 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
Flow numbers an more useful info on almost any chevy head available.
http://users.erols.com/srweiss/tablehdc.htm#Chevy
Old 01-24-2009, 06:27 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's because the valve don't open much more than that on the small heads
Old 01-25-2009, 08:33 AM
dmaaero
dmaaero's Avatar
I don"t think dart makes the 180 pro 1 in platinum.
Old 01-25-2009, 08:47 AM
1972warship
1972warship's Avatar
From what I understand the pro 1's are all platinum design. The dart iron eagle 180 is not the platinum design.
Old 01-25-2009, 09:14 AM
Guru_4_hire
Guru_4_hire's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
When dart was going through the development process for the platinum heads, they found that the 180s were already really good in their wet flowing testing and as such did not need modifications like the rest of the line.
Old 01-25-2009, 11:22 AM
76 sting
76 sting's Avatar
nice heads.... I am hoping to get mine dyno'd as soon as the weather warms up a little.
Old 01-25-2009, 05:44 PM
gkull
gkull's Avatar
Received 1,330 Likes on 1,058 Posts
The heads reach max flow at .500 So additional lift only has the same CFM. All heads reach a max cfm at some lift point.
Old 06-24-2009, 11:11 PM
spcl67
2nd Gear
spcl67's Avatar
Default Iron eagle platnum 200cc
Hi just finished bulding a 383 using Iron eagle platum 200cc heads took them to local race shop and had a good port job on them with 2.08 1.60 valves at 600 lift the flowed 305 intake and 217 ex. The guy that ported the heads said they were one of best heads to work with he has flowed some of these heads that went over 323 on the intake side at two horse power per cmf these heads make tons of power. Just bump the the gas and the set you back in the seat. I,m running JE pistons, and Comp Cam full roller cam 9-990-9, Intake is SUPER VICTOR 2925, hooker super comp headers, hp Holly 1000 carb. I also have a cheater nos plate system with 250hp hit. MSD 6 digital box light the fire. This car stall at 3200 and flys to 7000 between shifts eats stock sprot cars for lunch no doubt best bang for your buck is platnum heads.
Last edited by spcl67; 06-24-2009 at 11:26 PM. Reason: Mis spelled a word. also added MSD paragraph
Old 03-26-2010, 12:46 PM
ssgnco
ssgnco's Avatar
I know this is an old post, but I've been looking for this information and just found it. Posting it for anyone who info on DART head flow numbers.
Cheers
Greg
DART Pro1 & Iron Eagle Platinum
Valve 2.020" 2.020" 2.055" 1.600" 2.080" 1.600"
Lift 180Int 200Int 215Int StdExh 230Int 230Exh
.200 134 145 152 125 160 122
.300 187 194 193 152 206 158
.400 231 242 239 178 247 198
.500 257 274 273 195 280 208
.600 261 284 289 205 297 214
.700 264 280 293 208 307 219
Bore = 4.030" all except 230 - 4.155"
with 31.5 deg back cut
NOTE: These numbers can vary by 5% in production
Old 07-25-2010, 08:41 AM
JAKE
JAKE's Avatar
I know this is an old thread, but what about this:
http://www.usaperform.com/platinum-a...ach-p-106.html
Jake
Old 07-25-2010, 05:37 PM
427Hotrod
427Hotrod's Avatar
Received 1,877 Likes on 915 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I didn't get a chance to flow them, but we just used a set of 200's on a Dart SHP 400" pump gas motor and made 554HP/520 lb ft with them using a 750 Holley.
JIM
Old 07-26-2010, 02:16 AM
JAKE
JAKE's Avatar
According to a couple of different sites, max flow is listed, in fact .700". Dart only listed the .500" flow number for the 180s.
One thing I found important is that the flow didn't go DOWN at the higher valve lifts as some heads experience.
Jake
Old 10-05-2013, 02:31 AM
spcl67
2nd Gear
spcl67's Avatar
Hi done some more work to the 383 I had full port put on my 2925 and picked up a bunch of time and power. I got a chance to run my camaro at A good stick track. I ran a 10.88 @ 122 in a 3500 lb car on motor, the sixty foot time was a 1.2 .
My best time was 9.70 @ 136.8 with 180 shot of nitrous.
The 1/8 mile time was 6.1 @ 110 mph. I will post a video of my last run when I get time.
Old 10-06-2013, 02:08 AM
bluedawg
bluedawg's Avatar
Nice maybe low nines with the 250 shot.
To Dart Pro 1 Platinum flow numbers ?
Quick Reply: Dart Pro 1 Platinum flow numbers ?
