How do I polish my cast iron crankshaft?
Always turn the crank in the direction of rotation - never backwards.
When degreeing the cam, you want to keep the timing chain tight in the direction of rotation as well.
If you are "dialing in" TDC with a dial indicator on top of the piston (heads off) to set your degree wheel, you still want to turn the crank in the direction of rotation - Backing up may give false readings on your dial indicator as well.
Piston stops screwed into the spark plugs are not a great way to establish TDC IMO - Might as well just rely on your balancer marks.
you must hit the center of the dwell..hence "TOP DEAD CENTER"
