Hooker side pipes will they fit on a vortec heads?
hi
like everyone else i have been looking at swapping heads. but i also want to get Hooker side pipes in the future, so will they fit on a vortec heads? if not, could i use some sort of adapter?
and if so can you guys post specs and/or pics of your setup.
thanks
thanks
I don't know if Hooker headers will fit Vortec heads. But I do know that Stahl makes their headers to fit your heads. They will ask you what heads you have, and then they may ask you to send templates of your heads.
When I ordered mine, they already had the template for my Brodix big block heads. Mine fit PERFECT (except I had to dimple #5 to get the Steeroids linkage unbound). If you jack the car up high enuf, they are really easy to install. The workmanship on the headers was flawless! Here is an old pic of them before ceramic coating. I don't have recent pics yet after I got them back from Jet-Hot.
I had 2 complaints with the Stahl sidepipes:
1) they turned out way too far from the side of the car. I had to cut them. A 10" chop saw did the job well
2) I had to fabricate a bracket to mount them. I welded a bolt onto the bottom of the pipe, then attached the bracket to the underside of the tranny x-member.
If I had it to do over again, I would try the Hooker sidepipes with the Stahl headers.
they will fit ok ,, but there is clearance issue for spark plugs as i understand
i have hooker comp. headers & planing to get the vortec 062 i may do some mods
on the headers as needed
Yes, they bolt up fine but yes it is difficult to get to all the plugs, at least it is with my older pipes without putting a couple small dents in them. This was a problem with the old heads too though.
