Piston Numbers
Piston Numbers
Anyone know if these piston numbers are for the same engine? We have 7 pistons with a number L2307A standard. 1 piston is 7040P standard. These were found in a box at a rummage sale.
Thanks,
Willie
Thanks,
Willie
Can't help you on the other piece.
454 should have pin about .115"-.117" higher (closer to oil ring) than in 427 piston
-edit_
FM says 2307 for 454 as above
clevite says 7040P interchanges to clevite 2241802 ... clevite says 2241802 also for 454.
if they look same & measure same ... they're probably for same motor.
