follow my C3 LSX - REMIX -
Well...
as some of you know. I blew up my 346...it was running 12.0@114
but it went bye bye...
OKAY...
Here is the CARNAGE !!!
The factory connecting rod let go at the shop when we put on a new carb spring KIT. Sounds Crazy but thats what happened. Along with me revving the motor to hard.
Anyways enjoy the photos.
OKAY...
It was a very good runner.
With Help From BOWTIE AUTO in Longwood... we tuned it and ran it. Car ran strong and made very consistant numbers.
Best time 12.008
Best MPH 114.6
Best 60 ft 1.72
racing record 44 wins and 7 losses (street and strip racing)
WELL FLOW ME ON MY PROGRESS WITH MY NEW SHORT BLOCK !!!
see a few pics and video below.
http://s243.photobucket.com/albums/f...t=MVI_6167.flv
Best time 12.008
Best MPH 114.6
Best 60 ft 1.72
Hey Sean....I was sorry to hear about the old motor, but the new unit should more than make up for the trouble you been through. Give me a heads-up on your trial run, I'd like to be there.
Will your IRS take the additional torque? It might be wise to put half shaft loops on at the least, if you havn't already done so. I broke one on my 69 and don't want to go there again. The free turning end of a half shaft is an evil thing!
Good luck and have fun!
Hey Mike...
YUP HALF SHAFT LOOPS have been in the car for about 2 years. From Dragvette.com
Also...if you still wanna build a LSX carbed engine I have Lots of good extra parts. I can send you a list if you like. All you would need a decent short block.
Thanks Sean, but my plate currently overflows and the heads I told you I had bought never came. Yeah...I got ripped by a member and trying to get my money back. You have some good parts there. Are those AFR heads being sold or going on the new motor?
Mike sorry about the HEADS was it a corvette forum member??
My new parts (AFR HEADS included) were damaged in the engine failure. My old intake, old 6.0 heads, 224 camshaft, and exhaust manifolds are perfect.
I just got my AFR heads BACK from repair...OUCH
sorry to hear about the motor. Similar thing happened to me but I had a lifter turn sideways on me. Lots and lots of metal shavings all over the motor. So I got a 416 LS3 forged & stroked shortblock. Then I topped it with some hand ported L92 heads and had a custom cam made for it. Lots of other custom parts too. I am curious to hear how much power your motor makes. Mine is "supposed" to be in the 630hp-650hp range at the flywheel.
Good luck and keep posting pics!
I am thinking about 460-500 rwhp (around 550-600 crank)
you seen this link
http://forums.corvetteforum.com/c5-t...post1568377786
Believe it or not thats a common problem with that LS-1 engine. My 2001 firebird wasnt over reved and got into it one day started driving it and bang rod thru the side of the block. Over on LS-1.com you see A lot of them shelling out like that.
Eagle forged crank and rods... diamond forged pistons and ARP bolts.
Fingers Crossed ....
Hi,
Do you have a thread/link showing what you had to do to the vette to get the LS1 to fit in your C3?
I see the 'sticky' link at the top of the forum but the amount of info is overwhelming to me.
Sure would like to see an 'HOW TO: LS1 in a C3' white paper in the tech section. Especially, a low-cost solution. My driveline is good for 400hp as it is 'new/rebuilt' from the Bow-Tie 700R4, shortened driveshaft, new blueprinted diff with 3.54 spicer gears, Van Steel halfshafts and Van Steel rear trailing arm/bearing assemblies.
Yes...and a popular character here as well.
Sombody will get some good parts, good luck!
Hi,
All is great with the motor. The tune needs some more work, but that will happen on the dyno this summer after the car is done being painted. And I am running a T56 6 speed. The cam is a custom grind from flowtech.
Here are a few videos of the motor running. Don't mind the body, I literally taped up the old front clip so I could drive the car.
http://www.vimeo.com/1949755
http://www.vimeo.com/2192411
http://www.vimeo.com/2262310
