What is this part?
What is this part?
On my '70....It is behind the license plate.. I can't find it in the AIM? I think there are 2 of them and one is missing on my car?
What is it?
Hey, Guy!
I think that part might be from the spare tire carrier.
It looks like the assembly that held the lock......
Just a guess... I hope I'm right and it solves your problem
Hi
That bracket should be bent back to the rear valance panel behind the license plate where you have the rusted nut below the license plate mounting nuts.The bracket should have a nut attached to it instead of the rusted ones.There should be one on each side.
Jeff
Jeff
Look in section 7 rearend and deck.They're there but a diff shape.
edit-I think in that shape they look the brackets under the frt floorboards that hold the heat shields.
Account disabled by user request 5 Jan 09
It has been bent way out-of-shape ...
See Corvette Central item #203111
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
in my 1968 AIM, it's located under UPC1, F21 ... your '70 AIM should be right around there I suspect ..
