Wiper Door
5th Gear
Wiper Door
Can anyone tell me why the wiper door on my 68 is in the open position, even when the wipers are off? The override **** is not in the on position. That was the first thing I checked.
it uses vacuum to open and close.
chances are the relay that switches where the vacuum goes is bad.
or there is a hole in the vacuum line that closes it.
Received 2,878 Likes
Hi 68,
Do 68's have the vacuum valve under the right side wiper arm in the wiper well? If they do it needs to be closed by the right side wiper arm coming down into the park position and signaling that it's O.K. for the actuator to close the door.
I'm sorry I'm not sure if 68's have this valve or not.
Regards,
Alan
Regards,
Alan
Hi 68,
Regards,
Alan
Regards,
Alan
Avner
Hi 68,
Regards,
Alan
Regards,
Alan
JR
thanks
I am having the same problem as well. After the vette comes back from the paint booth I will try to work this oout as well.....thanks for the info.
rt
rt
