Third Brake Light for C3
I´d like to remove the key swich to the alarm and to put in a LED with a wide spreading lens, to avoid cutting anything out of my rear end.
What is the size of the hole where the key swich is placed?
3/4"?
Can anyone advice me on where to find such a LED?
I´m not looking for a LED like the ones on mashines or so, I wan´t it to be real intense and wide.
Do you think it will work or will it just look silly with a single LED?
3/4"?
It might look funny if it's not real flat though.
Or maybe for a single light the DEI Lite'N Boltz that were mentioned earlier- I don't know how bright those are though.
Good luck with your ideas, I like the part of your car I can see!
Dan
It seems like you should be able to find a nice bright LED and mount to fit that hole. If you wanted more of a "bar" you might be able to make something like this:
Dan
Dan
I´ll check a little more about this and see what I can find.
My car can be seen here. www.coolvette.nu
