600+ cubic inches ?
Old 11-04-2008, 04:41 PM
zdave83
zdave83's Avatar
Default 600+ cubic inches ?
Does anyone have experience with 600+ cubic inch engines in C3's ? Where would you start if you were interested ?
Old 11-04-2008, 04:53 PM
Durango_Boy
Durango_Boy's Avatar
Send Big632 a PM about his car. He had a 632, and ironically, lives near you. I'm sure he'll have some info for you.
http://forums.corvetteforum.com/priv...=newpm&u=59116
Old 11-04-2008, 05:00 PM
Gordonm
Gordonm's Avatar
At the bank first!
I could not resist.
Old 11-04-2008, 05:09 PM
zdave83
zdave83's Avatar
Thanks Matt
Old 11-04-2008, 07:26 PM
Fonz69
Fonz69's Avatar
I have a 540 in my 69 which can be bored to a 632
The 540 is way too much motor for the car but I just happened to have one sitting in the garage so in it went
You plan on racing it?
Just wondering why so big
Old 11-04-2008, 07:38 PM
DRIVESHAFT
DRIVESHAFT's Avatar
Thats not exactly true. You are short 1/2" of stroke as well (4.25 vs 4.75)
600 cu in is going to require a tall deck block, which makes it a bit tougher to get everything to fit.
Are you sure a nice low deck 572 wouldnt make you happy?
Old 11-04-2008, 07:53 PM
Bowerss2
Bowerss2's Avatar
i would start by calling peterbuilt,
but seriously, check out world products. they are pricy, but realy high quality. World Products
Old 11-04-2008, 07:58 PM
l88rocket
l88rocket's Avatar
I have had a 632 and 706 on the street(not in a corvette), if for nothing else the awwww factor is a great reason to do it.. My 66 I haven't decided on building a big cube small block or a big cube big block, i have a tall deck small block that will go to 540
Old 11-04-2008, 10:10 PM
Rusted40
Rusted40's Avatar
one of these will move that much air with a 5 liter engine
and still get 5 liter MPG when you keep your foot out of it
Old 11-04-2008, 10:19 PM
Nobody.
Nobody.'s Avatar
I have a 598ci in my yellow '81 drag car. Definately alot of motor. But the car was built to handle it. In a street car, good luck. Maybe tone down the cam and compression, but it would still be a beast. At the very least, you're looking at $12k - $15k for a complete motor that big. I have built several so I know exactly what goes into them. Not to mention the money it would take to make the car capable of handling the power...
Old 11-05-2008, 07:24 AM
Fonz69
Fonz69's Avatar
I was refering to the DART block motor I have and what it said on the paperwork that came with it, that it could be safley bored to create a 632 motor.
It is a short deck with a 4.25 crank right now =540
Old 11-05-2008, 07:59 AM
427Hotrod
427Hotrod's Avatar
Received 1,874 Likes on 912 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
We built one for a buddy's C-3 project. It was a pump gas 632 designed for cross country running and racing like Drag Week and Power Tour. We detuned the cam a lot so it wouldn't have any trouble. We also did it so it could rev well past peak HP even with the smaller cam. It made 875-890Hp range on 93 octane. The heads were pretty small for it..but again it was designed with real street use in mind rather than peak HP.
It was just a cam and intake change away from 950+ HP even with the heads it had.
The engine ended up being sold to a Forum member in Ark. last summer for his C-3 project along with one of our favorite dana 60 IRS setups.
If you want to see another fun 632" project..do a search here on 632C2. That's another killer one but it uses Big Chief heads and nitrous!
JIM
Old 11-05-2008, 08:07 AM
bashcraft
bashcraft's Avatar
Boring alone won't get you to 632. You'll still need 1/2" more stroke.
Old 11-05-2008, 08:17 AM
Nobody.
Nobody.'s Avatar
And a tall-deck block. The most you can get out of a short-deck is 582ci. 4.600" bore and 4.375" stroke. You may get a little more if you bore it to 4.625" but that would max out the block which would not be the smart thing to do. 582 would be the max I'd go in a short-deck. I've built 3 of those for bracket racing and it's a great combo.
Old 11-05-2008, 06:52 PM
Fonz69
Fonz69's Avatar
Found the paper work I had on the block when I bought it about 5 years ago.
On it max cubic inch is 632, BUT I did not see that its a generic sheet that is describing the Dart 9.8 AND the Dart 10.2 Tall block
Learn somthing new every day:o
Here are the specs on my cam which was designed for my jet boat and a blower. It made over 1200hp on 110 octane with 9 psi boost pushed the boat over 120mph on the water at 6700rpm
I left the cam in for the 69 vette cause it only had about 15 hours of use, it might not be the ideal cam for the street but it sure goes
Isky solid roller.....
Cam lift / Valve lift / DUR / .50DUR / Lobe center / Hot lash
I-392 / .686 / 320 / 284 / 110 / .028
X-374 / .654 / 330 / 286 / 110 / .030
Motor has the billet main caps, ARP bolts,Dart pro1 aluminum 325cc heads (as cast) with inconel exhaust valves, titanium retainers, comp pro magnum roller rockers, Victor jr. intake port matched with a quickfuel 850, MSD ignition hooker jet hot side pipes with 2.5 sweet thunder inserts
Old 11-05-2008, 07:55 PM
zdave83
zdave83's Avatar
You plan on racing it? Just wondering why so big
Originally Posted by Rusted40
one of these will move that much air with a 5 liter engineand still get 5 liter MPG when you keep your foot out of it
Wow lots of good advice, thanks. No 'real' racing, I just have a thing for big, high torque engines in street cars. Throw in a mild SC, even better. Something with 80-100% more hp/torque than an L98 in the same rpm range would be perfect. As a street car get to enjoy all the power in day-to-day driving, plus you can drive it all day without getting tired of it. Hopefully it doesn't take $12-15K to build an engine like that (minus the SC), or a fortune to prep the rest of the car. Not cheap, but not like a drag car either.
Thanks again everybody!
To 600+ cubic inches ?
Quick Reply: 600+ cubic inches ?
