THD400 to Tremec 5 spd final results
I actually did it with no beer. I like to save that for after the install.
There is not a tag but numbers stamped into the bottom of the case. Find the numbers and post them and we can help you out. The gears may have also been changed over the years so this would render the numbers on the case useless.
The best way is to mark the tire. Rotate it exactly one turn and count the number of revolutions the pinion turns. If it turns3 1/4 times you have a 3.36, 3 times a 3.08 and 3.5 turns a 3.55 and so on.
I did not know that about the tag.
Once we can determine the rear gear ratio, we need to figure out when the torque starts to come on and then we can recommend a transmission to go with.
Richard
http://www.youtube.com/watch?v=F2qv8liIyok
This is an invoice on a transfer from a 76 Auto to Man drive: just a thought...for someone interested in doing this..
QUOTATION
Date
10/2/2008
Quotation #
8211AR
Name / Address
KEISLER ENGINEERING, INC.
2250 Stock Creek Blvd.
Rockford, TN 37853
SALES REP
GENE
90 day no interest financing available with approved credit.
Total
Subtotal
-15% Restock fee on ALL returns
-A $300 fee will be due on ALL cancelled transmission orders
-Returned Material Authorization number (RMA) REQUIRED for all
returns
-No refunds on special order items
KEISLER 5-SPEED for 1955-82 CORVETTE
You will likely find this new modern transmission the BEST driveline improvement of
your Corvette. Here are a few key points:
1. LOW RPM 5TH GEAR CRUISING - It will lower the engine RPM by 32%, 18% or
36%, making the car more fun to drive and quieter in highway traffic, plus extending
engine life and lowering fuel consumption.
2. FAST ACCELERATION 1ST GEAR - The lower 3.27 or close ratio 2.87 1st gear
will get your car moving FAST.
3. "BOLT-IN & GO" by KEISLER - Exclusive design with no cutting or alteration of the
car body, frame or interior required. CORRECT shifter position.
4. COMPLETE KIT - Everything you need
5. #1 SOURCE for OVERDRIVE TRANSMISSION SYSTEMS - the proven industry
leader with thousands of satisfied customers.
Read articles about this product, review customer testimonials and order ONLINE at
www.keislerauto.com or CALL 865-609-8187 x1
Read articles about our product in
CORVETTE FEVER, VETTE and
CORVETTE ENTHUSIAST
magazines ONLINE
Web: www.keislerauto.com
E-mail: sales@keislerauto.com
888-609-0070 ext. 1
Phone
Alt. Ph.
Fax
Description Qty Cost Total
76 VETTE 350 3.08Keisler Engineering key points:
1. Authorized warranty center for Tremec
2. Factory type leak inspection on all transmissions
3. In-house quality control and assembly
4. Correct shifter geometry
5. Built-in shifter noise reduction
You will see a dramatic reduction in noise, vibration and harshness with this swap in addition to
a 30-50% increase in fuel economy!
0.00 0.00T
TRG-RO4616A, KEISLER 500HP/500FT-LB 5-SPEED TRANSMISSION ASSEMBLY, INCL:
KEISLER CUSTOM BUILT TKO-500 WITH LOW PROFILE INTERNAL OFFSET SHIFTER,
MINI-BILLET SHIFT TOWER WITH SPECIAL 2-BOLT LEVER, 4616 CHROMOLOY GEAR
SET, 1PC COUNTER SHAFT, DUAL SPEEDO OUTPUTS, REVERSE & NEUTRAL SWITCH
OUTPUTS, 99LB WEIGHT, RATIOS: 3.27, 1.98, 1.34, 1.0, 0.68
1 3,295.00 3,295.00T
SALES - PLEASE SPECIFY DRIVESHAFT 1 0.00 0.00T
CROSSMEMBER/ISOLATOR BRACKET FOR C3 1 0.00 0.00T
ISG-622378, TRANSMISSION MOUNT, GM-TKO AND MOPAR A41, RUBBER 1 0.00 0.00T
SELECT SPEEDOMETER CABLE BASED ON YEAR OF VEHICLE 1 0.00 0.00T
Page 1
QUOTATION
Date
10/2/2008
Quotation #
8211AR
Name / Address
Rockford, TN 37853
SALES REP
GENE
Total
Subtotal
Sales Tax (0.0%)
returns
CORVETTE ENTHUSIAST
magazines ONLINE
888-609-0070 ext. 1
Phone
Alt. Ph.
Fax
S.O. ENTRY ONLY. CORRECT PART TO BE DETERMINED AFTER DIFF. GEAR RATIO
ADVISED BY CUSTOMER.
1 0.00 0.00T
REVERSE LIGHT WIRING HARNESS PER REVISION 0 1 0.00 0.00T
PBG-57080, SUPER HD NEEDLE PILOT BEARING, GM APPLICATIONS 1 0.00 0.00T
HWG-PACK A, PACK A, TRANSMISSION-BELLHOUSING HARDWARE 1 0.00 0.00T
HWG-PACK B, PACK B, ISOLATOR-CROSSMEMBER HARDWARE 1 0.00 0.00T
SPEEDOMETER CONNECTION HARDWARE, INCLUDES CLIP, 2 O-RINGS, BOLT AND
LOCK WASHER
1 0.00 0.00T
SHIFT LEVER HARDWARE FOR TKO AND T-56 1 0.00 0.00T
HWG-PACK H, PACK H, ISOLATOR-TRANSMISSION (TKO500/600) HARDWARE 1 0.00 0.00T
MAG-00603, INSTALLATION MANUAL, TKO, GM, CORVETTE 1968-82, REV. 3 1 0.00 0.00T
SLG-C3EV-NP5, 5-SPEED NAMEPLATE, 1968-1976 CORVETTE 1 0.00 0.00T
DUST COVER WITH MOUNTING SCREWS 1 0.00 0.00T
TRG-C3V500, KIT TOTAL: 550HP 5-SPEED KIT, INCLUDING NEW QUICK LAUNCH
RATIO TRANSMISSION AND ALL BASIC INSTALLATION COMPONENTS FOR 1968-82
CORVETTE. 6 MONTH PRODUCT WARRANTY, 2 YEARS FROM PURCHASE.
3,295.00
11" GM 621 REPLICA BELLHOUSING, TITANIUM/ALUMINUM CONSTRUCTION WITH
DOUBLE WALL THICKNESS, MADE EXCLUSIVELY BY KEISLER, 6.29" DEPTH, FOR 168
TOOTH FLYWHEEL AND INCLUDES INSPECTION COVER WITH HARDWARE, .003
TOLERANCE
1 249.95 249.95T
FWG-1469, GM OE CAST FLYWHEEL, 1955-85 ENGINE WITH 2-PC CRANK SEAL,
INTERNAL BALANCE, 168TOOTH WITH 11.0/12.0 BOLT PATTERNS (ALT SELL ITEM
FWG-460130-0 WITH 10.5/11.0/12.0 PATTERN, BILLET STEEL)
1 149.95 149.95T
Page 2
QUOTATION
Date
10/2/2008
Quotation #
8211AR
Name / Address
Rockford, TN 37853
SALES REP
GENE
Total
Subtotal
Sales Tax (0.0%)
returns
CORVETTE ENTHUSIAST
magazines ONLINE
888-609-0070 ext. 1
Phone
Alt. Ph.
Fax
CLA-K5552, 11X1-1/8 26SPLINE PERFORMANCE CLUTCH KIT, 450FT-LB, INCL:
MODERN PEDAL EFFORT PRESSURE PLATE, CLUTCH DISK, PREMIUM USA SEALED
RELEASE BEARING, ALIGNMENT TOOL, LUBE PACK
1 249.95 249.95T
#910 GM/MOPAR PRESSURE PLATE BOLT, SET OF 6 1 15.95 15.95T
#912 CHEVY/MOPAR/FORD FLYWHEEL BOLT, SET OF 6 1 15.95 15.95T
SLG-C3EVETTE, C3 EARLY SHIFT HANDLE, 1968-1976 CORVETTE, BLACK CHROME,
KEISLER 5-SPEED (SILVER USED ON 1968)
1 100.95 100.95T
SBG-056, LOWER SHIFT BOOT, RUBBER, 1968-82 CORVETTE 1 35.95 35.95T
SBG-057, UPPER SHIFTER BOOT (3 & 4 SPEED) LEATHER, 1970-76 1 35.95 35.95T
CLUTCH & BRAKE BUMPER 1 3.95 3.95T
C3 PEDAL ASSEMBLY 68-82, RECONDITIONED WITH NEW PADS; INCL LINKAGE
ASSEMBLY
1 459.95 459.95T
EXHAUST SUPPORT BRACKET FOR C3 VETTE 68-82, WITH TKO ** NOT NEEDED
WITH SIDEPIPES **
1 20.00 20.00T
Keisler exclusive TKO thorough quality check inspection, including bench test and automated
machine leak testing. Keisler handles all service needs after the sale with full machine shop
capability and skilled trans technicians on hand.
1 0.00 0.00T
SUBTOTAL 4,633.50
Page 3
QUOTATION
Date
10/2/2008
Quotation #
8211AR
Name / Address
Rockford, TN 37853
SALES REP
GENE
Total
Subtotal
Sales Tax (0.0%)
returns
CORVETTE ENTHUSIAST
magazines ONLINE
888-609-0070 ext. 1
Phone
Alt. Ph.
Fax
SHIPPING AND HANDLING 165.00 165.00
Page 4
$4,798.50
$4,798.50
$0.00
QUOTATION
Date
10/2/2008
Quotation #
8211AR
Name / Address
Rockford, TN 37853
SALES REP
GENE
Total
Subtotal
returns
CORVETTE ENTHUSIAST
magazines ONLINE
888-609-0070 ext. 1
Phone
Alt. Ph.
Fax
0.00 0.00T
Page 1
QUOTATION
Date
10/2/2008
Quotation #
8211AR
Name / Address
Rockford, TN 37853
SALES REP
GENE
Total
Subtotal
Sales Tax (0.0%)
returns
CORVETTE ENTHUSIAST
magazines ONLINE
888-609-0070 ext. 1
Phone
Alt. Ph.
Fax
1 0.00 0.00T
LOCK WASHER
1 0.00 0.00T
3,295.00
TOLERANCE
1 249.95 249.95T
1 149.95 149.95T
Page 2
QUOTATION
Date
10/2/2008
Quotation #
8211AR
Name / Address
Rockford, TN 37853
SALES REP
GENE
Total
Subtotal
Sales Tax (0.0%)
returns
CORVETTE ENTHUSIAST
magazines ONLINE
888-609-0070 ext. 1
Phone
Alt. Ph.
Fax
1 249.95 249.95T
1 100.95 100.95T
ASSEMBLY
1 459.95 459.95T
WITH SIDEPIPES **
1 20.00 20.00T
1 0.00 0.00T
SUBTOTAL 4,633.50
Page 3
QUOTATION
Date
10/2/2008
Quotation #
8211AR
Name / Address
Rockford, TN 37853
SALES REP
GENE
Total
Subtotal
Sales Tax (0.0%)
returns
CORVETTE ENTHUSIAST
magazines ONLINE
888-609-0070 ext. 1
Phone
Alt. Ph.
Fax
Page 4
$4,798.50
$4,798.50
$0.00
[QUOTE=SpE3dF0x;1567741489]This is an invoice on a transfer from a 76 Auto to Man drive: just a thought...for someone interested in doing this..
$4,798.50]
Minus your $200 forum member discount and free shipping through Friday.
$4,798.50]
Hey Jeff,
I am over in Memphis and am interested in a 5-speed conversion for my 74 big block coupe. It has a 200-4R and 3.55 rear in it now.
Do you perform the conversions there at your facility? If not, can you recommend a shop in TN or nearby that does?
Thanks.
Thanks.
glad your happy with your conversion..... i am going the other way..... had a 4 speed car bought a 5 speed with al the fixin's never put it in but now am going to run a TH400.
tremec swap to replace Nash four plus three
What would a ballpark figure be on labor to swap out a nash 4 plus 3 with a tremec kit [I would supply all parts]? Thank you.
#33
Right off the bat a manual tranny gives you at least 35 more hp and a wide range of rpm choices.
The smile factor comes right up
