Without going into the engine, can you increase HorsePower by...
A Stock 1978 with 185 HP: Without going into the engine, can you increase that HorsePower by doing any/all of the following? If so, how much??
1. Change spark plugs to Racing Plugs and Best Plug Wires
2. Install Headers
3. Eliminate the Catalytic Converter
4. Install True Duals with a top-of-the-line Muffler System
5. Replace the Stock Breather with an Aftermarket One
6. Replace Stock Tires to a particular size
7. Higher quality Oil
8. Higher Octane Gas
9. Replace Stock Carb
10. Anything Else
Would any of the above help with Torque?
2. Install Headers
10. Anything Else
2. Install Headers
10. Anything Else
2. Install Headers
10. Anything Else
but with the stock set-up you hade more back pressure which gave you more torque at lower RPM, this is why in some cars youll see butterflu vlaves in the tailpipes, to increace/decrease back preassure in sync with the engins load
tires, oil sparkplugs ect wond do a thing for HP but you should change the oil, plugs, wired, and tires if needed anyway
Miles
St. Jude Donor '08
1. Change spark plugs to Racing Plugs and Best Plug Wires No.
2. Install Headers. Yes, maybe the best mod. you can do.
3. Eliminate the Catalytic Converter. Yes, its essential to do it when you install headers.
4. Install True Duals with a top-of-the-line Muffler System. Yes, same as previous point.
5. Replace the Stock Breather with an Aftermarket One. No.
6. Replace Stock Tires to a particular size. With such a low HP motor, no much difference.
7. Higher quality Oil. No.
8. Higher Octane Gas. No.
9. Replace Stock Carb . No, I'd rather to re-tune the stock after doing these mods.
10. Anything Else. I think thats pretty much it.
HamadUP has it right. No free lunch.
I'm curious as to why some people think that an aftermarket breather would create more power. The stock breather doesn't use any so what would be the gain?
Cheers,
Pete
1.6 RRs?
I don't know the flow rate of the stk heads, but they would benifit
w/1.6 RRs. I had TFS heads when I added 1.6s. The engine ran smoother, much cooler and the sweet spot went up 200 rpms.
Well worth the $. JMHO
Ricisan
Ricisan
Make sure to set up your timing when you do all of the above. Read up on it on some of the articles on this forum. If you are on a tight budget pass on the headers for now. They will add a little HP but a true dual exhaust, a good tune up, proper timing set up, and carburetor adjustment will give you your biggest bang for the buck without going into the engine. The stock Corvette exhaust manifolds are actually pretty efficient though not as "cool" as headers. All depends on how much you want to spend.
recurving the distributor to bring the advance in sooner will help with a bit more "seat-of-the-pants" power and well worth doing, and considering the only expense is the cost of a couple of springs from a distributor recurve kit it's cheap to do, but it's sure isn't going to increase power anywhere near 10% as mentioned. But if the distributor is still untouched from stock set-up you should feel a bit of difference.
The stock exhaust manifolds are fairly restrictive so adding a good set of headers, eliminating the Cat, and running true dual exhaust should gain you some more power you can feel also.
Everything else on your list is a complete waste of time and money and isn't going to gain you ANYTHING, especially "racing plugs"!! Give me a break! Run the correct plugs with the correct heat range for your motor and for street driving and stop reading the marketing BS in the parts catalogs. Race car parts are for race cars, NOT street cars. do yourself a favor and take your JEGS and Summit Racing catalogs, look them over very carefully for entertainment purposes only, than throw the d*mn things in the trash.
Hey look, that's twice we've agreed in one week. McFast is going to get jealous.
dont be so foolish as to throw those catalogs away, but do be careful of silly things like tornados for the intake and gas line magnets ect, ect
i do believe that an aftermarket "breather" or do you mean air filter, WILL increase power to a degree, hasnt anyone here heard of K&N?
also, tire size will do nothing to increase hp. but will have an affect on your overall gear ratio but it will not be enough to justify the cash output for tires.
tune that baby up real well and replace the springs and weights in the dist. and set the timing more advanced. you may even want to change the dist. all together. old and stock parts dont put out much energy.
all these little things wont do much by themselves but together they will make a difference. the exhaust is where youll get the most bang for the buck without going in the engine.
It all comes down to simply physics:
K&N advertises more power by allowing more air thru the filter therefore into the motor. simple concept and it works! If that is ALL you care about than go ahead and use a K&N filter.
What K&N fails to put into their lovely marketing brochures and advertising is that the only way to get more air through the filter is to use a filtering material that also allows more dirt particles through.
so, while you may pick up a slight increase of power you are alos getting more dirt inside your expensive motor. If that is a trade-off you are willing to do than by all means use their filters. i'm not willing to subject my motor to that abuse.
There is a forum member in the C1/C2 section who spent decades as an engineer for GM (in the corvette division no less). After he retired from GM he was recruited and hired by Chrysler and he was the Viper plant manager. during his time as the Viper plant manger Chrysler ran OEM tests on air filters because they were looking for the best performing air filter to use on the Viper. Obviously, on that vehicle power output from the engine was key. during the tests it was shown and proven that while the K&N filter allowed some of the largest power output between all the filters it also showed and proved that it allowed more dirt particles through than any other filter tested. Since Chrysler wanted a reliable vehicle and especially since they would be responsible for warranty service on the new vehicles they refused to use the K&N as an OEM filter on the Vipers.
Gaining possibly 1 or 2 HP simply isn't worth the downside of using inferior filtering capability to achieve the result.
You can block off the heat riser on the intake manifold for a cooler intake charge without going into the engine (other than removing the manifold).
