Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-29-2008, 03:04 PM   #1
LannyL81
CF Senior Member
Default Comp Cams 268H...anyone have this?
Installed this cam into my '81 rebuild...and now wondering what in the world I was thinking...
Anyone have this cam and driving it on the steet? In what engine? What base timing are you using?
Comp Cams state a 1500 - 5500 RPM range....is this going to work on the street?....what was I thinking
LannyL81 is offline   Reply With Quote
Old 09-29-2008, 03:28 PM   #2
baxsom
CF Senior Member
the 268 is the most popular cam on this forum it seems
baxsom is offline   Reply With Quote
Old 09-29-2008, 03:41 PM   #3
Gordonm
CF Senior Member
Gordonm's Avatar
For a stock motor with stock lousy heads like you have it will work but not like if you had some decent compression and a better set of heads. Beyond that I think the 268 is a very mild cam. Yes it can easily be run on the street. I would and do run a much larger cam on the street.
Gordonm is offline   Reply With Quote
Old 09-29-2008, 05:36 PM   #4
yellow 72
CF Senior Member
St. Jude Donor '09
yellow 72's Avatar
I had the Comp Cams 268H in my vette years ago with a mild 8.5:1 350. It would idle down to 650 rpm with just a slight lope. Good street cruiser cam
yellow 72 is offline   Reply With Quote
Old 09-29-2008, 07:13 PM   #5
baxsom
CF Senior Member
comp cams says that if you have an auto it is the largest you can run on stock torque converter doesnt it.
Old 09-29-2008, 08:01 PM   #6
Lee H
CF Senior Member
Support Corvetteforum!
I have this cam in my son's 72 1/2 ton short bed. Rebuilt short block with flat tops. Vortec heads, Lar's carb. 350 THM with shfit kit, stock converter. It runs good, nice lope on idle, will laydown a nice loooooooong chrip in second, and gets decent mileage. Good cam for every day driver.
Lee H is offline   Reply With Quote
Old 09-29-2008, 08:01 PM   #7
yellow 72
CF Senior Member
St. Jude Donor '09
yellow 72's Avatar
Quote:
Their catalog states that about the 270H...
Old 09-29-2008, 08:20 PM   #8
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
Comp Cams states my cam operates in the 3000 - 7500 RPM range. Works great on the street
__________________
1980 Corvette, 427ci Motown SBC 465RWHP N/A so far,500 is the goal, AFR 227 Eliminators
T&D Shaft Rockers,Vic Jr, XR286R solid roller,248/254 dur .640" lift 10.6:1 Mahle pistons
Eagle stroker rods, 4 in. Callies DragonSlayer crank, 825 Drag Race Demon, 3 in exhaust
Paint by Dream Car Garage......................................My'70 CUDALotsa ladies and lotsa trouble
MotorHead is online now   Reply With Quote
Old 09-29-2008, 11:14 PM   #9
bertmeister
CF Senior Member
bertmeister's Avatar
I have this cam in my 81. I added Edelbrock Performer aluminum heads with the 64 cc chamber size, and Stan's headers with a true dual exhaust and no emission stuff. This is a nice steeetable cam with lopey idle and nice pull to about 5000 rpm. Enjoy it.
bertmeister is offline   Reply With Quote
Old 09-29-2008, 11:45 PM   #10
1mpalss
CF Senior Member
1mpalss's Avatar
I've got this cam in my 350, using L98 aluminum heads, 650 Mighty Demon, Holley dual plane, and Hooker header/sidepipes. It pulls about 17" of vacuum at 650 rpm. I'm still tuning it and my tranny (stock turbo 400, not downshifting or upshifting properly) is not set up right but I think it runs really well. I've got 35 degrees of total timing, 12 degrees initial. I'm going to go with a 700R4 with my 3.08 gearing and finish dialing it in.
1mpalss is offline   Reply With Quote
Old 09-30-2008, 12:59 PM   #11
LannyL81
CF Senior Member
Quote:
My rebuild was not exactly stock; used flat top 2 valve relief pistons, and threw away the stock heads and used 882 heads, shaved 0.010 with 2.02/1.6 valves, bronze guides, Comp Cams 1.6 roller tip rockers, Hooker side exhaust headers, max flow mufflers. Compression is about 1 higher than stock.
Still using the stock intake and E3ME carb though...at least at this time as I was going to have to go through emissions testing...but not anymore....no moer EGR valve, AIR pump...all sitting on the shelf.
I was just wondering about base timing setting....originally was 8 BTDC...not sure it will go that low and idle.
Old 09-30-2008, 05:45 PM   #12
yellow 72
CF Senior Member
St. Jude Donor '09
yellow 72's Avatar
Don't worry about base timing, set dist. for 36* total and let the base fall where it wants
Old 10-02-2008, 11:32 AM   #13
LannyL81
CF Senior Member
Quote:
Thats what I did. I unplugged the computer, set the timing to around 10 BTDC; plugged the computer back in, then held the engine at 2000 rpm and set the timing to be 36-38. I did not go back and see what the base timing was afterwards with the computer unplugged....it was 12-14 with the computer plugged in at idle.
Old 10-02-2008, 11:35 AM   #14
yellow 72
CF Senior Member
St. Jude Donor '09
yellow 72's Avatar
Old 10-04-2008, 03:14 PM   #15
Johnboy3
CF Senior Member
I just installed a 268H into an 81 and dyno tuned it this morning. You guys are right on with the timing. Best runs were at 35 degrees. Intial on this car was 15.5.
The cam makes nice power and has a good sound at idle. Nice cam.
Johnboy3 is offline   Reply With Quote
Reload this Page Comp Cams 268H...anyone have this?
Tags
268, 268h, 270h, 350, 882, cam, cams, comp, heads, idle, lopey, setting, sock, stock, timing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
