Transmission - Will reverse but not kick down into drive
Old 01-04-2020, 03:42 AM
dmallen95
dmallen95's Avatar
Default Transmission - Will reverse but not kick down into drive
My transmission recently started slipping and as of today will not kick down into drive. I fear it’s on its way out, but I’ve read some things about vacuum and solenoids to the transmission. Is there anything else I can check before beginning to search for rebuild options?
Automatic 3-spd(stock transmission)
Old 01-04-2020, 12:06 PM
MelWff
MelWff's Avatar
Received 1,817 Likes on 1,606 Posts
Does the fluid look very dark and smells burnt?
Have you checked the linkage to make sure it is actually moving the transmission lever on the case into drive?
Have you checked the carburetor linkage to make sure the cable is correctly adjusted?
If it has been slipping and now wont move forward, in all probability it's time for a rebuild.
There are no external solenoids or a modulator failure that would prevent it from moving forward.
Old 01-05-2020, 08:30 PM
CA-Legal-Vette
CA-Legal-Vette's Avatar
Also make sure your fluid level is correct. Not sure why, but drive goes out before reverse when there is a fluid leak.
Old 01-06-2020, 07:37 PM
derekderek
derekderek's Avatar
Received 3,388 Likes on 2,633 Posts
O/D time. 200 or 700r.
To Transmission - Will reverse but not kick down into drive
Quick Reply: Transmission - Will reverse but not kick down into drive
