Rear end squats when put into gear
Hello,
Have an 81 automatic that the rear end squats down pretty bad when you put it in drive. Would the rear spring being worn out and weak cause this or is there another issue. The spring is the stock one as far as I know and it looks tired.
Any thoughts appreciated.
What spring do you have? The single fiberglass or the 7 to 9 leaf spring? The fiberglass spring rides soft from GM and if you idle at high speed 700rpm or more you will get an inch. This is normal from what I have experienced.
