Best Headlight actuator seal boots?
Ok
who has had luck with Headlight actuator seal boots?
the last two I have bought from different sources have torn in just a few openings....so who is the best vendor to get the boots from?
have bought them from most vendors and never had a torn one yet.Are you getting them in some kind of bind? (I always silicone them so the shaft slides easy.)
I've seen the joint bind and fail to rotate when the rod goes in and out which forces the shaft to one side.
I've bought a pair from Ecklers and they both failed within a month. Ecklers replaced them FOC and the replacements failed too.
The ones from MidAmerica have been more reliable.
I got my set from Zip several years ago. They seem to still be holding up well. Hopefully Zip is still using the same supplier as they did when I got mine.
