Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-02-2008, 05:57 PM   #1
Schaggy
CF Senior Member
Schaggy's Avatar
Default Help! Fuel Gauge Resistor?
Anybody know what I can replace this with?
It went across the posts on the back of the fuel gauge.
I assume from its construction that it's a resistor of some kind. If anyone knows where I can get one of these, or the resistance needed so that I can rig something, please let me know.
Thanks!
Schaggy
Schaggy is offline   Reply With Quote
Old 09-02-2008, 08:10 PM   #2
RunningMan373
CF Senior Member
RunningMan373's Avatar
I measured it before, i believe it was 30 ohms. If so digikey has a siutable replacement. they also will have any other value you might need. this one is a 5 watt-er, and is 1" long. Wrap the leads around once, cut off excess and tighten down the nuts.
http://search.digikey.com/scripts/Dk...e=ALSR5F-30-ND
From your picture, it looks like the wire is still intact. that means you can still measure it, with a Ohm meter. If your not familiar with them, take it to a local TV repair shop, and ask them to measure the resistance for you.
RunningMan373 is offline   Reply With Quote
Old 09-02-2008, 09:00 PM   #3
7T1vette
CF Senior Member
7T1vette's Avatar
Better yet, take it to Radio Shack. Those guys have nothing to do all day and will be glad to see someone come in.... Some of them even know how to use an ohmmeter. (Unless you know the guy, TV repairmen need money to do work.)
7T1vette is offline   Reply With Quote
Old 09-02-2008, 09:26 PM   #4
...Roger...
CF Senior Member
...Roger...'s Avatar
Are you sure that was across the fuel gauge?
Edit- ok minor brain fart...of course the fuel gage has one and it should be green if I remember correctly...I've got some numbers written down for them.
Lt blue-123 ohms
green -89
yellow-88
orange-86
blue black-81
...Roger... is offline   Reply With Quote
Old 09-02-2008, 09:55 PM   #5
RunningMan373
CF Senior Member
If it is 89 (90) ohms, As was my second choice, this will do you. Radio shack doesn't carry 90 ohm power resistors, just 100 ohm-ers. TV guy shouldn't charge you to take a resistane reading unless he's an... 'You be the judge'. Most Radio Shack guys i'v seen lately wouldn't know how to use a Multimeter to test a battery.
just shy of 1" long, insulated except for the leads, 5W power capable.
install as stated in original answer.
http://search.digikey.com/scripts/Dk...?name=91W-5-ND
Old 09-02-2008, 10:06 PM   #6
...Roger...
CF Senior Member
Quote:
I wonder now if I measured them correctly.You mentioned 30 ohms and I came up 81 to 123.I looked in the manual I cant find a list of their values.
Old 09-02-2008, 10:13 PM   #7
RunningMan373
CF Senior Member
Quote:
I couldn't find them listed either,, so I'm assuming it's a 90, from your measurments. Which should match the sender resistance. I measured mine when I had it out a year and a half ago, just remember it being a single value related to the sender reisitance. 90 ohms is probably it.
the wire on his apprers to still be intact,, so he should be able to get it measured or measure it himself.
Old 09-03-2008, 02:55 PM   #8
Alan 71
CF Senior Member
Alan 71's Avatar
I'm quite sure the resistor in the sender is 90 ohms.
Regards,
Alan
Alan 71 is offline   Reply With Quote
Old 09-03-2008, 05:49 PM   #9
RunningMan373
CF Senior Member
Quote:
Regards,
Alan
No one's talking about the resistor in the sender, were talking about the resistor across the back of the fuel gauge.
Old 09-03-2008, 09:46 PM   #10
Les 94 Comp Yellow
CF Senior Member
If I am not mistaken the risistor in the photo is the one attached to the fuel sending unit in the gas tank. The float arm rubs against it to send the signal to the gauge in the cockpit. It is not a type like eveybody is showing in the link to Digikey. I don't know where to get one but if anybody does a post here would help. The ones shown so far wont work at all. The resistor that is needed works like a variable resistance or a potentiometer (spelling?). The original one is about 1/2 inch x 2" in length.
Les 94 Comp Yellow is offline   Reply With Quote
Old 09-03-2008, 10:55 PM   #11
RunningMan373
CF Senior Member
Quote:
"It went across the posts on the back of the fuel gauge."
Old 09-03-2008, 11:04 PM   #12
1Fordman
CF Senior Member
1Fordman's Avatar
Do you still have continuity through the resistor? If so why couldn't you tape or epoxy it to a popsicle stick or a small strip of plastic to keep it from flexing. Put it back on the gauge and see if it works.
1Fordman is offline   Reply With Quote
Old 09-04-2008, 11:59 AM   #13
7T1vette
CF Senior Member
7T1vette's Avatar
Since the wire is still intact, just use an ohmeter to measure the resistance from one end to the other. You could epoxy the substrate back together, but putting epoxy on the wires will make it difficult to dissapate heat. You could replace it with a 5W power resistor of approximately the same value. Remember, you just want to know when your tank is getting low...not how many gallons you need to put in.
Old 09-04-2008, 11:59 AM   #14
Schaggy
CF Senior Member
Schaggy's Avatar
Default About Testing
First off, thanks to everyone who's posted. I'd never straighten this out on my own.
Putting the thing on an ohmmeter seems like a great idea, but the wire is kinked in a number of places. Now I'm not an electrician, but I'd think that the kinks would change the resistance (impedance?). Does anyone know if this is true?
-Schaggy
Old 09-04-2008, 03:14 PM   #15
7T1vette
CF Senior Member
7T1vette's Avatar
The 'kinks' change NOTHING. If the wire isn't broken, it still carries the same resistance. Just measure the darn thing and let us know what you get. We're trying to help you.
Old 09-04-2008, 03:31 PM   #16
Alan 71
CF Senior Member
Alan 71's Avatar
Running Man,
You mentioned the fuel sender ohm number in your post and that you thought it was 90 but couldn't quite remember. I was concurring.
Regards,
Alan
Old 09-04-2008, 04:49 PM   #17
RunningMan373
CF Senior Member
Running Man,
Regards,
Alan
Alright, thanks. best bet it just measure the thing and then replace it. 5w 91 ohmer will be more the adequate. C,.
Old 09-05-2008, 11:25 AM   #18
Schaggy
CF Senior Member
Schaggy's Avatar
Default Got it Tested
It is 90 Ohms. I'll be picking up the proper resistor at the local electronics store this weekend.
Thank you all for your help!
-Schaggy
Reload this Page Help! Fuel Gauge Resistor?
Tags
1968, 71, 77, corvette, fuel, gauge, resistor, resistors, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
