Coolant... Zerex vs Prestone green
I dont mean to start another yellow or orange thread
But seriously.. between Zerex green and Prestone green, which one is better for a 69 vette with original copper radiator?
Either one will be fine, I personally like Prestone and run it in all my vehicles. Don't buy the 50/50 premix it's a rip off. It's the same price as the non-dilluted stuff. I buy one gallon and split it, add water to make it 50/50 and wind up with 2 gallons of pre-mixed for the same price that they sell one for.
Location: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
1 Post
Funny you should mention the prices. I was just looking at some Prestone in Wallyworld about a hour ago. The 100% was $9.97 a gallon and the 50/50 was $8.97. The 50/50 has a warning on the label that says "do not add water" daaahhhh!!!!!
They must market that 50/50 stuff to people that can't figure out how to add water....
yeah normally convenient is more expensive up front.
but you can buy less of the pure stuff and a few gallons of distilled water and you are good to go.
I am by no means an expert but from what I have read and understand a choice in coolants is going to be like you choice in oils. Different strokes for different strokes kinda deal. Most brands are going to work just fine in a fully and normally functioning cooling system. The problems occur when there is lack of regular maintainence and also with choice of water. I myself use prestone yellow in my 1972 vette, 1991 chevy truck, 2000 vette, and my wife's 2002 Lexus. But I change them all every year or two and I only use RO-DI water to mix the coolant with. Reverse Osmosis Deionized water is completely pure and has a TDI ( total disolved solids) rating of like .002. So nothing is in it except H2O. No calcium buildup no nothing to worry about. So pick your coolant, go to a local aquarium store and purchase some RO-DI or even just DI water would work.... drain and flush your old garbage out, fill with the new and properly change it every year or two.
hth
Sully
hth
Sully
hth
Sully
hth
Sully
