Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-06-2008, 04:56 PM   #1
mxscooter
CF Senior Member
mxscooter's Avatar
Default Blower motor wiring?
Heya everyone how goes it
Just a quickie - I'm installing a switch to turn the blower motor on and off, and was wondering if/how anyone has done it? I figured I'd splice into that sucker and go to town lol...
Cheers,
Jeff
mxscooter is offline   Reply With Quote
Old 08-06-2008, 07:22 PM   #2
RunningMan373
CF Senior Member
RunningMan373's Avatar
80's a bit off from my '73, but on my '73, it's the brown wire from the heater/blower/AC fuse that is the single power in to the in car switch. cutting it and installing a switch will disable the blower in all positions. I would recomend you get a wiring diagram and trace the wires on your '80 before you start cutting. good luck,,C.
RunningMan373 is offline   Reply With Quote
Old 08-11-2008, 09:59 PM   #3
mxscooter
CF Senior Member
mxscooter's Avatar
Thanks for the reply
I have disconnected the plug from the top of the heater/AC box under the hood, and the blower still turns on and off. It's the 4 plug deal with 2 plugs horizontal and 2 plugs parallel, I was guessing this was the harness for the blower motor? It's a former AC car but still has all the old AC stuff installed under the dash and on the firewall.
I hope to check those fuses out tomorrow night and get this underway
Old 08-12-2008, 02:27 AM   #4
RunningMan373
CF Senior Member
That's the connector to the Blower motor resistor, it will still work on high with that unpluged i think. Cutting and switching the power in wire to the switch behind the dash will disable it completly, but what I suspect your trying to do is get it to not run on low. If it's a problem, i would suggest you check the seal on the air door behind the P/S kick panel. there is a cable that closes and opens it. you can bend the center part of the cable into a slight 'V', to get it to close farther. this rid my interior of the heat problem. C.
Old 08-12-2008, 12:14 PM   #5
mxscooter
CF Senior Member
mxscooter's Avatar
(in a Vincent Price voice): "Eeeegg-zellennnt"
I should be able to get to it hopefully after my new baby is asleep tonight lol...
Thanks again
Reload this Page Blower motor wiring?
Tags
1984, 66, blower, corvette, dash, harness, inside, motor, vette, wireing, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
