C3 63-82 Chassis Torque Specifications
Old 08-03-2008, 09:59 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default C3 63-82 Chassis Torque Specifications
I have been busy replacing all my 71 Coupe suspension components and now its time to re-assemble. I had to search to day for a complete list of C3 Torque Specs. I eventually I found them. Found a post that stated that the complete list is in the VANSTEEL parts catalogue ( on page 9 ).
So to help others, I copied it and will list it here:
Corvette Torque Specifications
1963 – 1982
Brakes:
Caliper Mounting Bolt - Front..........70.........5/8
Caliper Mounting Bolt - Rear ..........70.........5/8
Caliper Housing Bolts - Front.........130........13/16
Caliper Housing Bolts - Rear ..........60.........5/8
Rear Suspension:
T-Arm Front Toe-In Shims.............50+*.......5/8 & 11/16 nut
Spring Retainer To Rear End ..........70.........13/16 bolt (de arch spring)
U-Joint (inner) U-Bolts...................15.........9/16 nut
U-Joint (inner) Caps......................30.........9/16 bolt
U-Joint (outer) Flange Bolts............75.........5/8 (use locks)
Strut Rod (Inner) Camber Bolt .......70*........3/4 nut
Strut Rod (outer) Shock Mount .....75+* .......15/16 nut
Shock Absorber (upper) Bolt ...........60..........5/8 & 11/16 nut
Shock Absorber (lower) Nut ............40..........3/4
Bearing Housing to T-Arm ...............30..........9/16 nut
Spindle Nut ...................................100+. .......11/16
Warning: If the assembly was not properly set-up, tightening the spindle nut
will load the bearings and cause imminent bearing failure.
Wheels:
Rally Wheels (steel).........................75...... ....3/4
Optional Wheels (aluminum) ...........80*.........3/4 (re-torque at 100 mi.)
Front Suspension:
Upper A-Frame Bushing Bolt .........35*........9/16
Upper A-Frame Align, Shim Nut......50.........11/16
Lower A-Frame Fr. Mtg. Bolts ........70.........5/8
Lower A-Frame Rear Mounting......100........7/8 & 13/16 nut
Steering Arm to Spindle ................70.........3/4 Nuts (63-68, 11/16)
Ball Joint (upper) .........................45+........3/4 nut
Ball Joint (lower) .........................75+........7/8 nut
Ball Joint (replacement bolts) .........25.........1/2
Carrier:
Front Brackets to Frame ...............65.........5/8 & 11/16 nut
Front Brackets to Housing ............50+........5/8 & 11/16 nut
Strut Rod Bracket Bolts ................35.........9/16 (use locktite)
Rear Cover Bolts..........................50....... ..5/8
Filler Plug ....................................20
+ plus additional torque when necessary to align cotter pin hole
* tighten bushings only when arms are at riding height
I have been doing this stuff for years and I was surprissed to see this!
" * tighten bushings only when arms are at riding height* " I guess really you learn something new everyday.
Hope this info helps someone!
Bill C
The following 14 users liked this post by Bill Curlee:
'78CorvetteS.A. (06-03-2020), 1967droptop (07-20-2023), 20mercury (06-02-2020), 80vette21 (04-28-2020), AkrHack (02-28-2018), Alex66 (05-18-2016), JohnRR (02-05-2020), Kidster71 (04-26-2020), kneelandt (04-19-2020), Last Triumph (10-05-2021), rmrtrex (11-05-2023), Ron69Az (02-28-2017), warrenflx (11-15-2019), wheelhouse73 (06-02-2020) and 9 others liked this post. (Show less...)
Old 08-04-2008, 09:04 AM
BenUK
BenUK's Avatar
Thank you Bill. That'll be very useful for me soon.
Old 08-04-2008, 10:29 AM
Jud Chapin
Jud Chapin's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Very nice work!
Old 08-04-2008, 10:51 AM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Thank you this is a great post !
Having all the Torq specs in one place !
69VETT
Old 08-04-2008, 07:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No problem! I usually spend all my time in C5 Tech but, this 71 is starting to need a bit of attention! I'll be hanging out here more and more!
Ill post some "HIGH LIGHTS and Lows of my suspension upgrade project after its all complete so others can learn from some of the stuff that I had to go through. Like cutting out the trailing arms! Man, I wouldn't wish that job on my worst enemy! Those suckers were rust welded in place!
Bill C
Old 06-07-2011, 04:03 PM
bobbarry
bobbarry's Avatar
Thanks for compiling that; for some reason, the assembly-manual doesn't list the torque for the inner U-joints when it uses caps; it only lists the torque for the nuts when using straps.
Old 06-07-2011, 05:54 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi,
The GM Chassis Service Manual has a pretty nice list of torque specifications too. It's divided into areas, so is easy to use, and quite complete.
Regards,
Alan
PeteZO6 (06-02-2020)
Old 06-07-2011, 07:47 PM
PeteZO6
PeteZO6's Avatar
As does the AIM. Torque values are given on each drawing where there are bolts, etc. Very handy to print the pages covering the area you are working on so you can refer to them as you disassemble and reassemble each component, part, assembly, etc.
Pete
Old 06-07-2011, 09:43 PM
mikep3
mikep3's Avatar
What is the torque on:
Lower control arm bushings.
Bolts that hold the steering box to the frame.
Old 06-07-2011, 10:19 PM
bobbarry
bobbarry's Avatar
Pete
Unfortunately, the AIM I have for the 1971 model year, on page L166, shows only the U-bolt/lockwasher/nut, with a torque spec of 14-18 LBS FT, with no alternative drawings for the HD caps retained by bolts that are on my '71.
johnt365
johnt365's Avatar
Bookmark. Thanks, I needed that.
Old 07-15-2011, 01:17 PM
bobbarry
bobbarry's Avatar
Originally Posted by woodsman731
I need help.
I have a 69 427/390 and some parts are NOT numbers or year correct.
My Vette was born in November 1968.
I need the starter, alternator (core stolen by mechanic) and the Q-Jet carb. that would be numbers and year correct.
If anyone out there has these parts or know where I can scarf them up please let me know!
Thanks,
Terry Cowan
815-541-6818
You would do better to post what you need in the Parts For Sale/Wanted forum:
http://forums.corvetteforum.com/c3-p...ale-wanted-57/
Old 08-17-2013, 03:36 PM
JBmac
JBmac's Avatar
Awesome Bill!!!! Thanks I just used it for the wheel bolt torque specs on the wifes 71 Big block vette!!! All the folks on this site are the best!!! JB
Old 08-09-2015, 02:06 PM
mashmc
mashmc's Avatar
Default Thank you
1963 – 1982
Brakes:
Rear Suspension:
Wheels:
Front Suspension:
Carrier:
Bill C
2015 and still being used thanks
Old 08-10-2015, 05:05 AM
dgheinen
dgheinen's Avatar
I know it's an old post, but I assume all of this is in ft/lbs?
Old 08-10-2015, 10:41 AM
woodsman731
Cruising
woodsman731's Avatar
Default Torque Specs.
Thank you Bill!
Old 08-10-2015, 02:29 PM
mashmc
mashmc's Avatar
Default Torque
Bill C. Made it very easy to look up torque requirements, I found this a useful chart with everything compiled, I had looked up some and found that they are in Ft/Lbs. I printed it and hung on my shop wall, saved me a lot of time in Look-Up.
Old 06-02-2020, 12:42 PM
wheelhouse73
wheelhouse73's Avatar
This is the best ever. thanks!
Old 11-04-2023, 04:22 PM
C3FIXER
C3FIXER's Avatar
Damn, I wish I had Had this when doing the re-assembly.
To C3 63-82 Chassis Torque Specifications
Quick Reply: C3 63-82 Chassis Torque Specifications
