Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-06-2008, 12:32 PM   #1
Spitfire80
CF Senior Member
Spitfire80's Avatar
Default Painting calipers....
Gents....
Getting custom wheels for my 80 Corvette.
Aluminium Break calipers will be exposed a bit. Would like to paint them....
Any suggestion ?
Do I need "high heat" paint ?
Spray or paint brush ?
Phil
Spitfire80 is offline   Reply With Quote
Old 07-06-2008, 12:37 PM   #2
Roughrider
CF Senior Member
Roughrider's Avatar
Send a message via MSN to Roughrider Send a message via Yahoo to Roughrider
There is a spray caliper paint available at places like Pep Boys, but what I did was buy a kit from Eastwood made for the purpose. It's a two part high heat epoxy paint. Once you mix it you have to use it quickly as it hardens quickly.
It comes with everything you need and in many colors. Check their web site. It's not at all difficult to use and is quite durable.
Roughrider is offline   Reply With Quote
Old 07-06-2008, 03:01 PM   #3
hwcoop
CF Senior Member
hwcoop's Avatar
I used "Cast Grey" on my calipers and when my rotors were new I masked them off and sprayed all the surfaces not contacted by the pads with Silver High heat caliper paint. no more rust issues and the paint appears to be holding up to repeated braking
hwcoop is offline   Reply With Quote
Old 07-06-2008, 03:18 PM   #4
timbo79
CF Senior Member
timbo79's Avatar
Send a message via MSN to timbo79
I used the duplicolor stuff. There is also a product called G40 (I believe) that works well.
timbo79 is offline   Reply With Quote
Old 07-06-2008, 05:32 PM   #5
7T1vette
CF Senior Member
7T1vette's Avatar
If you just do normal driving, any good quality paint will do. If you really use the brakes, you should go the high-temp route.
7T1vette is offline   Reply With Quote
Old 07-06-2008, 11:21 PM   #6
Dantana
CF Senior Member
Dantana's Avatar
I powder coated mine.
Dantana is offline   Reply With Quote
Old 07-07-2008, 03:57 AM   #7
gingerbreadman1977
CF Senior Member
gingerbreadman1977's Avatar
Send a message via MSN to gingerbreadman1977
i used semi gloss black engine paint. has been on for 6 months and looks the same as the day i sprayed it.
gingerbreadman1977 is offline   Reply With Quote
Old 07-07-2008, 04:33 AM   #8
stinger12
CF Senior Member
stinger12's Avatar
Powdercoat.
stinger12 is online now   Reply With Quote
Reload this Page Painting calipers....
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help on painting calipers!!!!! unbeliveable350 C5 General 14 07-07-2005 11:59 PM
Painting calipers - removing wheels joehoya17 C5 General 28 05-09-2005 07:07 AM
Finished my calipers-- well maybe what do you think VLVETTE C5 General 38 01-24-2005 12:38 AM
painting calipers jerseynick C5 General 32 12-15-2004 07:58 PM
Opinions on painting Calipers Eric 96 C4 General Discussion 28 07-26-2003 12:52 AM
Question about painting calipers... Turbo-Jet C3 Tech/Performance 15 08-22-2002 09:35 PM
Painting calipers. MEATHOUSE C5 Tech 15 10-21-2001 06:20 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
