Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-06-2008, 10:50 AM   #1
AWilson
CF Senior Member
AWilson's Avatar
Default Fiberglass cloth Vs mat
It seems that no one mentions fiberglass cloth for repairs. Everyone talks about mat. How come? I believe cloth is many times stronger. Mat is unheard of in aviation use due to it's poor performance. You would have to use a bi-directional cloth but to me it would be better. Unless I hear from you guys to the contrary, I will go with the crowd and use mat but I though I would post this thread for the heck of it.
AWilson is offline   Reply With Quote
Old 07-06-2008, 11:13 AM   #2
Jud Chapin
CF Senior Member
St. Jude Donor '11-'12
Jud Chapin's Avatar
As I understand it, cloth fibers can show through the final product while the mat will not. It's also more difficult to work with when dealing with corners, etc.
Jud Chapin is offline   Reply With Quote
Old 07-06-2008, 11:53 AM   #3
ZL1powr
CF Senior Member
ZL1powr's Avatar
The cloth patern will definantly show through. The mat is also a better match to the material in the car and is plenty strong enough for a repair. Relative to strength, the cloth is strong along the orthoganal fiber directions but very weak in the bias direction.
ZL1powr is online now   Reply With Quote
Old 07-06-2008, 06:37 PM   #4
chris75stingray
CF Senior Member
chris75stingray's Avatar
cloth shows through
chris75stingray is offline   Reply With Quote
Old 07-06-2008, 07:48 PM   #5
jnb5101
CF Senior Member
jnb5101's Avatar
cloth is stronger due to the long fibers, that's the reason cloth is used for structual pieces. also when repairing areas of complex curves cutting the cloth in strips about 1 1/2 " wide will allow the cloth to conform to the desired shape. if it's a cosmetic repair, sand the cloth to clean up the edges, then put down a layer of mat.
jnb5101 is offline   Reply With Quote
Old 07-06-2008, 08:14 PM   #6
427V8
C6 the C5 of tomorrow
Support Corvetteforum!
427V8's Avatar
Send a message via AIM to 427V8
Well the corvette body doesn't need to be all that strong.
The curves and the weave showing through is a biggerreason
427V8 is offline   Reply With Quote
Old 07-06-2008, 08:17 PM   #7
Road-Race Vette
Premium Supporting Vendor
Road-Race Vette's Avatar
I agree with everyone else. CLOTH WILL SHOW THROUGH. DO NOT USE IT!!!!!!!
Road-Race Vette is offline   Reply With Quote
Old 07-06-2008, 10:08 PM   #8
2000FRCZ19
CF Senior Member
2000FRCZ19's Avatar
i have used cloth with great results but i used a layer of mat over the cloth to prevent it from showing though. i put the cloth down first for strength then added the mat over the top of it. this combo is very strong and does not let the cloth show through. if you are not going to use mat over the cloth then it will show through.
2000FRCZ19 is offline   Reply With Quote
Old 07-06-2008, 10:55 PM   #9
brngrhd
CF Senior Member
brngrhd's Avatar
Send a message via AIM to brngrhd Send a message via MSN to brngrhd Send a message via Yahoo to brngrhd
hey i hear it will show through....... but that is only what i hear.
brngrhd is offline   Reply With Quote
Old 07-06-2008, 11:19 PM   #10
Chucks82
Junior Member
Chucks82's Avatar
When your working from molds cloth is much stronger period. Also from
those same molds you first apply Gel coat or primer, then add the cloth
usually lighter weight first. This aids to help hide the print of the cloth.
For the repairs on the vets unless its really a large area you gain little
strength from cloth. Angel hair or other types of fibers are easier to float
into small cracks and sand without the cloth weave showing. Then go
over it with rage and your pretty much good to go. I take the angel hair
past the cracks about 3" and then float it from there.
Chuck
Chucks82 is offline   Reply With Quote
Reload this Page Fiberglass cloth Vs mat
Tags
angel, bidirectional, cloth, corvette, coth, fiberglass, hair, illinois, mat, mats, matt, repair, vendors, vs, weave
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Who else here agrees that GM contracted some C4 parts out to the lowest cost dizwiz24 C4 General Discussion 26 12-05-2003 03:10 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
