Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-30-2008, 08:32 AM   #1
minxdog
Junior Member
minxdog's Avatar
Default Water Pump
I'm getting ready to drop in a new crate motor in a 1979 and I am confused on what what water pump to use . Does it have to be corvette specific,or can I use a short pump with a shim kit behind the pulley? Also does this water pump run counter clockwise or clockwise I've been told both. That's why I figured I better check on this forum, you guys have been the best source of information since I started this project. thanks
minxdog is offline   Reply With Quote
Old 06-30-2008, 11:04 AM   #2
71rdster
CF Senior Member
Get the Corvette specific water pump. It willl be one less thing to worry about and one less thing to cause the next owner to cuss at you when he starts working on it. The pump should be standard rotation if you are using all the original pulleys and brackets. If you are using a serpentine system, you will need to verify whether the setup is for reverse rotation or standard.
71rdster is offline   Reply With Quote
Old 06-30-2008, 11:06 AM   #3
80Vette80
CF Member
80Vette80's Avatar
80Vette80 is offline   Reply With Quote
Old 06-30-2008, 11:22 AM   #4
Durango_Boy
CF Senior Member
Durango_Boy's Avatar
Send a message via AIM to Durango_Boy
I agree with the above. Get a Corvette specific pump for your year so you don't have to shim a pulley. That's just inviting run out and vibration problems.
At the same time, you want a clockwise rotation pump, which is standard rotation for your Vette. Reverse rotation, or counter clockwise, was not started until GM started putting serpentine belt systems on engines.
Durango_Boy is offline   Reply With Quote
Old 06-30-2008, 11:55 AM   #5
69Vett
CF Senior Member
69Vett's Avatar
Default Corvette water Pump only ??
Anyone have these specs. for a corvete pump only ?
I used a standard "Short pump" High volume,
I used all orginal pulley and brackets, no shimming required.
just fired up my motor no belt aligment issues.
good luck...69VETT
69Vett is offline   Reply With Quote
Old 06-30-2008, 11:55 AM   #6
justaguy10825
CF Senior Member
justaguy10825's Avatar
Send a message via Yahoo to justaguy10825
Hate to sound like a dumb-dumb but "Corvette specific" water pump? I guess I did not know that when I put my 350 in...The belts do not line up perfectly and there is some vibration in the alternator bracket when running. I guess I thought it was just something I would have to live with...
I have been intending to change out the pump anyway because it is not the shiny chrome one but have also been thinking about an electric pump... Has anyone had any experience with the electrics? & Does anyone have a part number or affordable place to buy on a "Specific" conventional chrome pump for a 78 w/350?
Thanks!
justaguy10825 is offline   Reply With Quote
Old 06-30-2008, 12:02 PM   #7
Durango_Boy
CF Senior Member
Thanks!
Yeah, GM makes four water pumps for Gen1 small block engines.
Long - Clockwise
Short - Clockwise
Corvette short - Clockwise
Long - Counter Clockwise
You probably got a GM short pump, which is just a bit different than Corvette specific water pumps.
Here is a Corvette specific chrome water pump from Eckler's.
http://www.ecklers.com/product.asp?p...4&dept_id=1220
Old 06-30-2008, 03:21 PM   #8
71rdster
CF Senior Member
There is also the short Corvette reverse rotation pump for L98's
Old 06-30-2008, 03:23 PM   #9
jackson
CF Senior Member
good luck...69VETT
OE C3 sbc uses short pump thru ABOUT 1970 ... ABOUT thereafter OE C3 sbc uses vette specific. That's why late 60's C3 aligns w/ short w/ no problem but a late 70's C3 misaligns w/ short. earlier pulleys/brackets not same as later.
FYI ... V belt pumps rotate same as crank ... serpentine pumps typically reverse.
vette pump (~ 5.795") about 3/16" larger from block to hub face than short (~ 5.625")
jackson is offline   Reply With Quote
Old 06-30-2008, 03:40 PM   #10
69Vett
CF Senior Member
69Vett's Avatar
Default great info ! thanks !
Great info ! thanks !
and... that explains why I was able to use a standard pump on my 69 configuration. 69VETT
Old 06-30-2008, 05:04 PM   #11
lil_red_devil
CF Member
lil_red_devil's Avatar
I used the GM Performance 14011012 aluminum pump. Direct fit on my 79 and the pulley didn't need any shims. Also had 2 bolt paterns for different types of pulley. You need the clockwise pump for a standard setup or a reverse rotation if you have a serpentine belt conversion.
Hope this helps
lil_red_devil is offline   Reply With Quote
Old 06-30-2008, 05:46 PM   #12
lil_red_devil
CF Member
Quote:
Hope this helps
Aparently the part number has been superceeded by 19168604. Check it first though if you choose this pump
Old 07-01-2008, 02:11 PM   #13
justaguy10825
CF Senior Member
Quote:
Long - Clockwise
Short - Clockwise
Thanks for the info! I'll take a look...
Old 07-01-2008, 05:24 PM   #14
PeteZO6
CF Senior Member
PeteZO6's Avatar
Send a message via MSN to PeteZO6
Default Still confused, but that's normal...
This is all very interesting!!! When I built my engine, I used aluminum pump p/n 14011012 that lil_red_devil says is superseded. I just punched 14011012 into GMPartsDirect's web pagehttp://www.gmpartsdirect.com/ and it comes still comes up.
In any event, that's not why I am posting here. My car is a very late (Nov.'69) can and i found the above pump placed the w/p pulley and fan 3/16" too far forward! To align the belts, I made this plate that fits between the harmonic balancer and the crank pulley.
Click the image to open in full size. (that is supposed to be an image, not just a link???)
This aligned the crank and w/p pulleys. I only have an alternator to accomodate, and that was easy with the Hooker alternator adapter I bought with the headers.
I'm still confused about short and Corvette short pumps, but that's how I got around the problem.
Cheers,
Pete
PeteZO6 is offline   Reply With Quote
Old 07-01-2008, 07:46 PM   #15
lil_red_devil
CF Member
Cheers,
Pete
The new part number seems to be the one used by summit and pace parts. Fitted this to my 79 and to a 78. Both aligned perfect. Both have had a CS144 alt upgrade and used the same bracket as before with the stock alt. I was also confused when looking for a pump. Both these cars are ps and ac cars. Maybe you have a different crank pulley? Or maybe I was just lucky
Old 07-01-2008, 11:08 PM   #16
GrandSportC3
CF Senior Member
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03 & '06
GrandSportC3's Avatar
Send a message via AIM to GrandSportC3 Send a message via Yahoo to GrandSportC3 Send a message via Skype™ to GrandSportC3
The only time that I'd use a Corvette specific pump would be on a all original NCRS car.. However, there's no real reason to go with a Corvette water pump on any other street Vette or Hotrod. You can get a high volume aluminum pump for $50, less than half the price of the iron pump that is Corvette specific..
I have a ProComp high volume pump on my yellow '68 and i'm running 170 to 190 degrees.. No alignment issues with the belt..
GrandSportC3 is offline   Reply With Quote
Old 07-01-2008, 11:59 PM   #17
noonie
CF Senior Member
noonie's Avatar
Cheers,
Pete
Normal rotation pumps for Corvette SB
From the pump mounting surface to the pulley mounting surface
Up to 70---5.625"----5/8" shaft
Up to 70---5.625"----3/4" shaft
71-82---5.795"----3/4" shaft
Long SB pump is 6.932"
Some pass cars and trucks also used both the 5/8" and 3/4" shaft short pumps.
noonie is offline   Reply With Quote
Old 07-02-2008, 03:39 PM   #18
PeteZO6
CF Senior Member
PeteZO6's Avatar
Thanks Noonie!
That makes sense. 5.795" - 5.652" = .17". My spacer at 3/16" = .1875. The pump I am using, p/n 14011012, is the longer short Corvette pump, and my crank pulley is for the shorter short Corvette pump since it's a 1969 model. My 3/16" spacer is off by 0.0175 or about 1/64", but it doesn't seem to be enough to bother the belts. The key was getting the alternator aligned properly which I was able to do.
Cheers,
Pete
Reload this Page Water Pump
Tags
14011012, 19168604, 1979, corvette, gm, number, part, performance, problems, pulley, pump, shim, short, standard, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette parts For Sale As of 5-20-05 jfaphoenix32 C5 Parts for Sale/Wanted 29 07-25-2005 09:13 AM
Replaced radiator, water pump and 160 thermostat, overheats worst now. DMONSVETTE C3 Tech/Performance 51 06-25-2005 12:51 AM
Optispark????? 93_LA_Vette C4 Tech/Performance 45 11-08-2004 04:48 PM
Meziere electric water pump GP tbyrne C5 Tech 42 01-27-2004 11:06 AM
New product - Meziere "street" electric water pump - bolt on 10-12hp! tbyrne C5 Tech 28 08-22-2003 02:50 PM
Meziere LT1 water pump on sale RichS C4 Tech/Performance 57 11-04-2001 10:35 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
