Symptoms of a wiped cam lobe or bent pushrod\bad valve?
Old 06-24-2008, 09:34 AM
78pacer
78pacer's Avatar
Default Symptoms of a wiped cam lobe or bent pushrod\bad valve?
I installed new intake and exhaust valve seals less then 3k miles ago in my '78 L-82. Everything went smooth and the engine ran fine. That was a few seasons ago. More recently, I backed from my driveway, threw her in drive, stepped on the gas and heard a loud carb backfire. The engine now hesitates on acceleration(feels like its running with the choke on, and it's not) and missfires slighty at all rpm's with an slight occasional pop sound (if you really listen closely)from the throat of the carb. I had been convinced it was the carb, (I checked the accel pump operation and it's putting out a healthy spray),but with the sudden onset of this problem with the backfire, and the ignition misfire, I'm not so certain its fuel related. Does this sound typical of a cam related or valvetrain problem? If so, how should I diagnose and proceed with tracking down this gremlin?
Any suggestions would be appreciated.
Thanks,
Mike
Old 06-24-2008, 09:49 AM
weimer20
weimer20's Avatar
A "wiped" cam lobe will manifest itself in a loud ticking valve. As the lobe gets ground down, the valve lash increases to the point that the rocker will smack the top of the valve making a bit of racket. Bent pushrod will do the same. You can check it by measuring the total valve lift at the valve with an accurate measuring device. (Dial indicator). What kind of carb are you running? Holley maybe? Reason I ask is due to the symptoms you have described. Fuel and timing issues come to mind. Not valves.
Old 06-24-2008, 10:19 AM
78pacer
78pacer's Avatar
I'm running an edlebrock q-jet #1903 hot air choke 750cfm. It is fairly new. I have a brand new MSD streetfire distributor and wires.(runs alot smoother but problem still present). I set the base timing to 12 deg btdc as a factory setup. No idea how to establish total timing.
Mike
Old 06-24-2008, 10:32 AM
Durango_Boy
Durango_Boy's Avatar
I would be looking at other things. Check for a vacuum hose that popped off. The timing may be off, and you would be wise to check all the plugs and wires. Pull the plugs and check their color. Also pull the cap and check the rotor and contacts.
Old 06-24-2008, 10:44 AM
weimer20
weimer20's Avatar
As DB stated, I'd be looking at other areas as well. Really doesn't sound like a cam / valvetrain prob. Your carb has me stumped a bit. I rebuilt q-jets many years ago. Enough time for my recollections to fade. I'll look up that carb and see if I can identify any potential troublespots there. My thoughts are going toward ignition though. Looks like DB is thinking the same. Follow DBs advice and I will continue to pick my brain.
Old 06-24-2008, 11:24 AM
78pacer
78pacer's Avatar
Thanks Durango boy and weimer20.
The plugs are all new. The wires are MSD8mm. They are brand new, along with the distributor. Two of my old wires were cracked at the cap and arching, and the old distributor was original. Plug # 3 and 5 was wet with fuel.
Old 06-24-2008, 12:16 PM
weimer20
weimer20's Avatar
The plugs wet with fuel... Was that before the wire and dist switch or did you just find that? Ya know another thing I was thinking... Wonder if there may be a rocker that is to tight? Possibly holding a valve off the seat a bit. Just a thought. Do you have a compression tester? (this is just a thought as you had stated that the seals had been done. ) Thinking out loud here.
Old 06-24-2008, 01:11 PM
The Money Pit
The Money Pit's Avatar
Pull the valve covers and eyeball the rockers. Mine had a few loose, and the engine was running OK, but a bit rough.(Hard to tell when the normal idle shakes the fenders.)
When I pulled the intake I found this.
Old 06-24-2008, 01:49 PM
Durango_Boy
That was a 'little' rough?
Old 06-24-2008, 02:00 PM
78pacer
78pacer's Avatar
weimer20,
That's a great idea, but I did that before buying the new MSD distributor. The compression in one cylinder was 155lbs. All others were 165lbs. I squirted some oil in the cylinder and tried it again and brought it up to 165. No wet plugs after the changeover. I did put a vacuum gauge on a manifold port and am pulling between 10-12 in. Is that too low?
Mike
Old 06-24-2008, 02:04 PM
78pacer
78pacer's Avatar
Thanks moneypit.
I hope I don't have anything that resembles that. Gheesh. The car has no pollution crap and headers. It's fairly loud, but if my pushrods were like those, I think I'd be hearing a lot of rattles.
Old 06-24-2008, 03:55 PM
weimer20
weimer20's Avatar
Originally Posted by 78pacer
weimer20,
Mike
10 - 12 is ok on the vacuum. Do you have a timing light to get a look at where you are set right now??
Old 06-24-2008, 04:31 PM
78pacer
78pacer's Avatar
I set my base timing at 12 deg BTDC as the manual suggested.
Old 06-24-2008, 06:00 PM
weimer20
weimer20's Avatar
May want to look at it again. Dist may have moved or worst case cam chain jumped. Again, thinking out loud.
Old 06-24-2008, 09:04 PM
Gearhead74
Gearhead74's Avatar
Default Carb Backfire
I bought a 64 Impala 283 when I was younger. It had a backfire through the carb at any RPM higher than 2500. Real low RPM seemed to be OK. I figured it was dwell so I bought the car.
Turned out to be a flat lobe on an exhaust valve. Apparently the spent gas couldn't get completely out of the cylinder during the exhaust cycle so it flooded into the intake manifold when the intake valve opened.
I'd suggest pulling the valve covers and looking very closely at the rocker arms while the engine is running. If it's just started to wear you won't see it, but if it's worn somewhat more it will be obvious.
Old 06-24-2008, 09:44 PM
78pacer
78pacer's Avatar
Thanks again weimer20,
I considered the fact that the timing chain may have lept a tooth or two. Is there anyway to check it without removing the front of the motor? Would\could a timing chain out of synch cause a hesitation/stumble off of idle as well?
Gearhead74,
Thanks for the reply. This backfire is barely noticable upon a steady 2-3k throttle. At idle, it isn't there, or I am too deaf to notice...*s
The engine miss is prevalant more when the engine is warm then when warming up and so is the hesitation. Weird eh?
Any thoughts?
Mike
Old 06-25-2008, 08:00 AM
The Money Pit
I had a Firebird Formula back in 80 that the catalytic converter plugged up and caused a similar issue. Idled OK, but as soon as you started driving would choke up the engine and backfire through the carb.
I doubt timing gear jumped teeth, That kind of stuff only happens on very high mileage, never maintained vehicles, which I hope is not the case here.
Have you checked the plugs, cap and rotor? Maybe it's something simple.
To Symptoms of a wiped cam lobe or bent pushrod\bad valve?
Old 06-25-2008, 08:05 AM
bojangies46
bojangies46's Avatar
Gearhead74,
Any thoughts?
Mike
Make sure your timing is correct and advance is working, check intake for gasket leak, a warm intake will expand more than a cold one.
Old 06-25-2008, 08:50 AM
78pacer
78pacer's Avatar
Thanks The Money Pit,
I recently replaced the distributor with a brandy new MSD streetfire unit. I also changed plugs and new 8mm MSD wires too. I needed a distributor, so this was a great time to swap it out and perhaps solve two issues at once. Well, the engine now holds time and runs smoother, but the hesitation and missfire is still prevalant. I have stainless headers and a gutted converter. It almost seems to be running on 7.5 cylinders..*s I do appreciate the input. We'll get this somnab**ch sooner or later.
Ahhh....bojangies46,
You may be onto something. I have seen oil weeping down the pass\front side of the intake onto the front of the head. Very slight, but still there. Would a vacuum leak produce a missfire as well as hesitation? I put a vacuum gauge on a manifold port of the distributor and produced 10-12inHG and it was steady. I wouldn't mind canning that old plate-blocked off EGR manifold in lieu of a nice edelbrock performer.
Mike
Old 06-25-2008, 09:37 AM
Matt Gruber
Matt Gruber's Avatar
pick a date on your calander:
Adjust valves if not fixed by then.
Quick Reply: Symptoms of a wiped cam lobe or bent pushrod\bad valve?
