View Poll Results: Do you feel safe running on slip fit trailing arm bearings?
Yes
41
48.81%
No
43
51.19%
Voters: 84. You may not vote on this poll
Is it Safe to Slip Fit TA Bearings?
This subject has come up before and now I see it again. The question is...do you feel safe running on slip fit bearings in your trailing arms?
Low horsepower,stock tire cruiser I wouldn't worry too much.I'm not a big fan of slipfits and I would never recommend but I do have a half dozen cars that I service and they are much easier to work on.
Just a few reasons.
At a minimum the slip fit slips. If nothing else you get wear like this over time. Then it is impossible to set the clearances.
Then things like this can happen. If it does, you can loose the wheel and axle. Both of these did.
On the others the bearing failed. On this one just the shaft broke.
No, For several reasons.
Just a few reasons.
Just a few reasons.
Definitely not.... but there are others who will argue the point!
There has been a lot of discussion recently on slip fit and also in the past.
There seems to be a point that doesn't get discussed too much.
Based on wombvette's picture, there is clear evidence that the bearing race has slipped and ruined the axle.
My question...
Slip fit or not, the inner races on the axle are sandwiched together with a spacer and shims, held tightly with 100+ ft Lbs. of torque, by the axle nut.
At what point are the bearing rollers able to provide enough friction to over come the 100+ lbs torque holding the inner race in place.
If the bearing becomes that dry or beat up, I don't think a slip fit or press fit is going to make much difference. Bad things are going to happen.
I agree that a slip fit can be dangerous if you twist off an axle. The chances of that are so low, it's hardly an issue.
The chances of blowing a tire are much greater and somewhat as dangerous. How many of us are running high speed rated tires.
I'm not trying to argue the point, just trying to put some reality into the discussion.
If your bearings are greased and in good condition, then slip fit is not an issue. Unless you count axle breakage.
With slip fit, you can check/grease the bearings easily to ensure many years of trouble free driving.
Yes, I have slip fit bearings, for over 25 years now.
Yes, I have raced my Vette.
Yes, I have twisted both axles and have replaced them.
No, I have never had a bearing race turn on the axle.
Just my thoughts.
Thanks, Barry
My question...
Just my thoughts.
Thanks, Barry
No. The spindle usually snaps at the splines. Once that snaps, the only thing holding the rest of the spindle in the support is the press fit inner bearing. The brake caliper bracket doesn't care - it will snap off once the inner bearing slips off of the spindle journal. Then you will lose a tire.
My question...
Just my thoughts.
Thanks, Barry
My question...
Just my thoughts.
Thanks, Barry
I agree with most of what you say, but you would not believe how many units I get in my shop that have no sleeve and shim. They try to set them up like the fronts and just drop the cotter pin in the castle nut and let er go. Some are tightened with no shim or sleeve which is disasterous. You might have good luck and get long service from slip fit, but think about it. A lot of development went into these things. Lots of high paid engineers, with the best test facilities in the world and no axe to grind either way. They thought it was necessary. I`m going with them.
PS: I'm not trying to start a fight, so don't take it the wrong way please.
I have only had 1 come in without the sleeve and shim but both rear axles showed signs of the inner race spinning.Leaving the sleeve and spacer out is a no no.I set it back up with new axles and press fit.
I will guarantee to you that Chevy Engineering felt they were absolutely necessary, or it would NOT have been designed that way. In the 1960's, GM was all about making money...any un-necessary part would have been eliminated, in order to save a dime [or even less]. No way would a spacer and shim be left in the design when it meant extra co$t...unless it was necessary!
I doubt it. That would reduce the contact area on the spindle flange and splines...not a good idea. You'd have to make the spindle longer and then make a new spindle support to house the new spacer and shim for the bearings. You'd also have to shorten the half shafts to keep the stock location of the wheel in the wheel well. To save time they put the endplay spec between 0.001-0.008. That is too much, but can you imagine how slow the process would have been if they set the spec to 0.001-0.002? They cut corners on the endplay, but they didn't cut corners on the pressed bearings for a reason - safety. I'm done bickering now
I would not consider the bearing width discussion you and I are talking about bickering.I think their might be a market for a retro-fit assembly to make the rear bearing less scary for guys that dont have the tools to work on them.Really dont you think that it the reason for the slip fit mod?
One other thought-instead of using the same bearings and moving them away from each other how about using a bearing like front wheel drive cars have and like is in the rear wheels of a C5?
