76 floor pan replacement
Old 05-22-2008, 04:13 PM
pete44
pete44's Avatar
Default 76 floor pan replacement
Is it necessary to take body off frame to replace floor pans?..I have mine gutted out to bare floor..Thanks in advance,Pete
Old 05-22-2008, 05:42 PM
Durango_Boy
Durango_Boy's Avatar
They can be cut out and replaced with the body on the car.
Old 05-22-2008, 09:59 PM
78Vette-SA
78Vette-SA's Avatar
As DB said:
Old 05-22-2008, 10:38 PM
Oldguard 7
Oldguard 7's Avatar
What is the adhesive used to hold the floor pan in place? It was not welded?
Old 05-22-2008, 11:20 PM
78Vette-SA
78Vette-SA's Avatar
Yes, first it was welded. I drilled 1/4" holes around then sort of spot welded it in place as the original. I used weld-thru primer on the mating side. Then after the welding was completed I used Seam-Sealer all the way around. I drilled 3/16" holes in the front and riveted the fiberglass toe-board to the front of the pan.
You can see where the "spot" welds were done in the tunnel area.
After finishing off the toeboard, priming and painting. In this shot I had the body off again but you don't need to to do the pans.
Old 05-23-2008, 11:48 AM
jrodiw
Cruising
jrodiw's Avatar
Where did you get the floor pans from?
Old 05-23-2008, 05:58 PM
78Vette-SA
78Vette-SA's Avatar
Paragon (www.corvette-paragon.com)
http://www.corvette-paragon.com/cata...D-9DD088FE4836
Part #'s 6509 (left) and 6508 (Right). Retail is $259 each.
To 76 floor pan replacement
Quick Reply: 76 floor pan replacement
