6al
Try one wire from the connector of the blower resistor.... there is a 12V. switched with 25 Amps fuse!
I don't remember the color..... but with a multimeter should be easy to find the right one....
I'm lazy. I used the switched power lead to the original coil- not the resistor wire-my car didn't have that- it was the old TI (K-66) ignition.
Go to the fuse box- there should be a terminal marked IGN- tap off of that with a wire no smaller than what goes into the MSD box.
