12558062 Vortec heads
Old 07-02-2022, 05:12 PM
Fatpig
Fatpig's Avatar
Default 12558062 Vortec heads
Will 12558062 heads bolt up to my 1976 l48 350? My research so far says they will. I am following up here as the next step. Any clearance issues with the intake and carb? Stick with the qjet or go with edelbrock? Thanks.
Old 07-02-2022, 06:25 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Yes, they should bolt up. You’ll need a Vortec specific intake. This may cause hood clearance issues, requiring you to switch to a low rise air cleaner.
Assuming your Q-Jet hasn’t been hacked by someone along the way, I would stick with the QuadraJet. The 1976 QuadraJet has over a decade of engineering refinement added to it vs the Edelbrock.
Fatpig (07-03-2022)
Old 07-02-2022, 06:46 PM
Jarhead 74 Vette
Jarhead 74 Vette's Avatar
Like Shark Racer said, yes, they will bolt right up, but you will need a Vortec specific intake.
I wanted to run an RPM Air Gap intake on my 74, but ended up buying an Edelbrock Performer EPM intake for my crate 357. I have yet to install it, but hoping for the best.
The EPM shows pretty decent numbers for a “low rise” intake, and are nearly an inch shorter than the Air Gap (if memory serves me right).
There are mixed feelings between QJet, Edelbrock and Holley. Personally, I like Holley carbs as they’re simpler to tune, but I hear that once you get a QJet dialed in, it’s there and runs GREAT!
Best of luck!!
Greg
Fatpig (07-03-2022)
Old 07-02-2022, 10:26 PM
BKbroiler
BKbroiler's Avatar
You will also need self aligning rocker arms with the Vortec heads. They don't have push rod guide plates.
The following 2 users liked this post by BKbroiler:
Fatpig (07-03-2022), HeadsU.P. (07-03-2022)
Old 07-03-2022, 12:20 PM
Fatpig
Fatpig's Avatar
Thanks to the guys who responded with good info. I was able to purchase these 062 Vortec heads for $200. They are able to handle .500 lift and have Z28 springs. Magnafluxed and cleaned.
Old 07-03-2022, 11:10 PM
Jarhead 74 Vette
Great price for complete Vortec heads in good running condition!
Old 07-04-2022, 07:33 AM
BKbroiler
BKbroiler's Avatar
You might want to consider changing to screw in studs. Relatively cheap and easy.
Old 07-04-2022, 07:36 AM
Fatpig
Fatpig's Avatar
Thanks for the info. What are the advantages of doing that?
Old 07-04-2022, 07:44 AM
Fatpig
Fatpig's Avatar
[QUOTE=Fatpig;1605359836]Thanks for the info. I found a really good video on youtube that explained to me why this is a god idea. I am definitely going to do this. https://m.youtube.com/watch?v=ejih8y7wli4#menu
To 12558062 Vortec heads
Quick Reply: 12558062 Vortec heads
